Old 11-27-2008, 08:27 AM   #1
Kennethh
Question
Hey everybody!
I`m planning to start on my 79 C-10 pickup prosject soon. And i just bought me a 90 C1500 pickup as well, i shall be using that as a donor car. I`m taking the motor and transmisson from that car.
But my question is: Can i use the frame? Is it the same? What is the difference in those to?
Kennethh is offline   Reply With Quote
Old 11-27-2008, 09:41 AM   #2
LONGHAIR
Re: Question
Welcome to the board.
Before I "step in it".....since I see you are from Norway. Are these trucks "Normal"? Meaning, are they of American origin? Many foreign encarnations of "Chevy" stuff can vary greatly.
In America there was a change of body styles between 1987 and 1988, but that was pick-up trucks only. The Blazers and Suburbans retained the older bodys until 1992 (I think) So your question falls right in the middle of those cross-over years. If the trucks you have were originally American they are different. If they were built for (or in) another country, they could be the same.....
Do they look similar on the outside?
LONGHAIR is offline   Reply With Quote
Old 11-27-2008, 10:08 AM   #3
Kennethh
Re: Question
The body style is different yes. The 90 C1500 is the same body style as my brother has on his pickup, see picture.
So i guess it isn`t the same? Do you know if i could use some of the suspension parts?
Old 11-27-2008, 11:42 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Question
No, you can't use the frame or the suspension. Ok, let me say that it's not a direct swap over. Anything can be done with skills, and the right tools.
The motor should be a 5.7 V8 or 4.3 v6 and either one will be throttle body injected(TBI). Transmission will be a 700r4. Those will swap over just fine, but you will need to retain the wiring and computer if you plan to run the TBI. You will also need an electric fuel pump to supply the TBI.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-30-2008, 01:27 PM   #5
Kennethh
Re: Question
Thanks for the answers! I`ll be taking the motor and transmisson then. Yes it`s the v8 with the 700r4.
Old 11-30-2008, 03:30 PM   #6
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: Question
Originally Posted by kennethh View Post
the body style is different yes. The 90 c1500 is the same body style as my brother has on his pickup, see picture.
so i guess it isn`t the same? Do you know if i could use some of the suspension parts?
welcome. Thats one sweet truck. Good luck on ur build
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 11-30-2008, 03:49 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Question
You will need to mod the transmission crossmember, or build a new one. I would get the drive shaft too. You might have to have a new one built, and you can use the yoke from the later model to ensure you have to correct fit.
Articles-
"Refining Sierra"
