#776 | |
Re: PO has me PO'd
Interior looks sweet AJ, I got the same shifter, so I guess my interior will look as good as yours ![]()
#777 |
Can't wait to retire!!
Re: PO has me PO'd
Fair enough!
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#778 |
Re: PO has me PO'd
Yeah, I just don't know enough about this motor, why not start new and be able to control the situation with proper maintenance
#779 | |
Re: PO has me PO'd
I'm going to pull mine apart, check everything out and replace as needed.
#780 |
Re: PO has me PO'd
IIRC, number 8 cylinder was the one that seemed to get the most wear, don't know why...good luck to ya
#781 | |
Re: PO has me PO'd
Actually I don't expect to replace much. My engine has only about 15,000 miles on the rebuild. The PO gave me a boat load of paperwork/receipts all for the engine work that had been done. We'll see though. With my luck, it will need a total overhaul. ![]()
#782 |
Re: PO has me PO'd
That is one tough looking crossmember...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#783 |
Re: PO has me PO'd
Is that a reference to "Army Tough"
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-16-2008 at 11:37 PM. |
#784 |
Re: PO has me PO'd
...been a couple weeks, what's the latest with your stuff?
#785 | |
Re: PO has me PO'd
![]() ![]() atleast that's the current slogan... wait till another 4 star needs an OER bullett comment and it will change, again... along with our uniforms, again
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 11-29-2008 at 01:08 PM. |
#786 |
Re: PO has me PO'd
Main thing is trying to get over sickness for the last three weeks...finally feeling better
After that crossmember, I've just bin staring.... Putting the front of the motor back together, permanently! Gotta figure out a PVC system, Ive got the Offy breather mounted, just have to buy a valve and plumb it into the air cleaner. Work on the exhaust to mount up everything, then it's on to carb, distributor, and radiator Then.... Vroooom, Vrooooom ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-29-2008 at 04:13 PM. |
#787 | |
Re: PO has me PO'd
Looking forward to the Vroooom Vroooom! ![]()
#788 |
Re: PO has me PO'd
Here is my current problem, I am done mockup and into final assembly. I want to bring the heater outlet hose into this location, but w/o a cobbled up looking mess. Soooo, I plan to make a W/P outlet tube longer and be able to thread into it a 45 degree 1/2"X5/8" barbed fitting. That alone could be a problem since that is not a standard fitting
#789 | |
Re: PO has me PO'd
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 Last edited by Chevyman63; 12-05-2008 at 07:29 AM. |
#790 | |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-05-2008 at 07:43 AM. |
#791 | |
Re: PO has me PO'd
![]() You know, I've never checked to see if the threads on a water pump are pipe threads or parallel. I just assumed they were NPT or it would be very hard to keep them from leaking. Hmmm.
#792 |
Re: PO has me PO'd
Ya buttt, this is an electric wp, and it may be metric. Try pipe dope sometime, really sealsLOL
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-05-2008 at 08:07 AM. |
#793 |
Re: PO has me PO'd
#794 | |
Re: PO has me PO'd
![]() Ok Jim, what brand and model do you have and I will check it out...I'm on it!
#795 | |
Re: PO has me PO'd
![]() I think its a Proforma, but I'll check Here's a pic of the outlet that needs to be longer so I can drill and tap a 1/2" NPT. The outlet from the water pump is 1" NPT ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-05-2008 at 03:32 PM. |
#796 |
Re: PO has me PO'd
Thanks Tim for the answer...Alum. 1"NPTX2 1/2"nipple(don't go there) with a full coupling. Now I can machine a flat on the factory Proform water pump outlet and drill and tap a 1/2" NPT female to put my hose barb in...again, don't go there, lol
Down the road I will modify this using thin wall pipe and the high pressure 1/2 coupling to eliminate the ugly threads that show Parts were here from Mcmaster-Carr in 1 day, the greatest hardware store you ever want to visit Pics?...OK ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-09-2008 at 01:02 PM. |
#797 | |
Re: PO has me PO'd
![]() Where exactly are you going to machine a flat and drill and tap for the hose barb? Just curious.
#798 |
Re: PO has me PO'd
#799 |
Re: PO has me PO'd
#800 |
Re: PO has me PO'd
Maybe you see something I don't? It is one of the thickest parts of the adapter, at least 1/4", more if drilled on the diagonal. I just ordered another one(1 1/2" instead of the 1 3/4"), so I can get rid of the rubber hose adapter, now it will be strait. LMK what you think, I misplaced my hose barb(craft), but the brass fitting is 1/2" NPT
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-10-2008 at 02:11 PM. |
