Old 11-29-2008, 11:30 PM   #1
ChadBice
What is Missing From My Frame...so far
I FINALLY got my truck into the garage to start disassembly. My cousin and I took the bed of last night and I noticed a couple of places on the frame where things appear to have been cut off. What is supposed to be here? Also, it I suspect that the rear end that is in it isn't what is should be in it; the tires stick out of the rear fenderwells by about 2" or so. What is the correct measurement from backing plate to backing plate? Thanks!
Chad
'71 Chevy SWB
ChadBice is offline   Reply With Quote
Old 11-29-2008, 11:34 PM   #2
chas350
Re: What is Missing From My Frame...so far
Cant see very well, could they be exhaust hanger remnents?
chas
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 11-29-2008, 11:36 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Are those rivited to the frame?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-29-2008, 11:38 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Did this use to be a long wheel base frame? The 2 circles behind the cab look like where the front bed mounts from a long bed would be. But I see your sig line says SWB.
If not, I agree with Chas.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-29-2008, 11:43 PM   #5
ChadBice
They have rivits, but the rest has been torched away.
Chad
'71 Chevy SWB
Old 11-29-2008, 11:56 PM   #6
ChadBice
Also, it is a stepside, if that makes a difference. I don't knonw if the frame has been modified at all or if it was a LWB at one time. Can I tell by the VIN?
Chad
'71 Chevy SWB
Old 11-29-2008, 11:59 PM   #7
mycool72
mycool72's Avatar
The front bed mounts are missing off the rail. I have a SWB and there are mounting points there factory...
mycool72 is offline   Reply With Quote
Old 11-29-2008, 11:59 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Is the SPID still inside the glove box door? Check the wheelbase on that. 115" for a shortbed, and 127" for a longbed.
Keith
Convert to disc brakes.
Old 11-30-2008, 12:00 AM   #9
ChadBice
Here is a bit better of a photo, but all I have is my camera phone right now.
Chad
'71 Chevy SWB
Old 11-30-2008, 12:04 AM   #10
71tahoe
71tahoe's Avatar
What bed was on it? The pieces on the frame rails are from the front bed mounts. There are pieces under the cab that are also from the front bed mounts. The piece on the crossmember I have no idea.
71tahoe is offline   Reply With Quote
Old 11-30-2008, 12:14 AM   #11
glock35ipsc
OK, it is a SWB frame, and you are missing the front bed mounts. In the pic below, there is one mount on the right, and the other is missing from the left. Those are the front mounts from a LWB. The two behind that are the ones you are missing. You can see the flat mounts behind them that you still have.
Bob
Old 11-30-2008, 12:14 AM   #12
ChadBice
It had a "modified" stepside bed on it the PO installed. It was just mounted in a couple of places to some crossmembers with a few long self tapping screws. The bed was mounted to the frame with two bolts through each of the crossmembers to the frame. It didn't look right.
Chad
'71 Chevy SWB
Old 11-30-2008, 12:18 AM   #13
ChadBice
Excellent! Thanks, Glock! Now the big question...is this something that is reproduced or do I need to start hunting for these?!
Chad
'71 Chevy SWB
Old 11-30-2008, 12:24 AM   #14
glock35ipsc
There are always guys parting trucks on here. Put a WTB ad in the classifieds, should be able to pick up a pair cheap.
Bob
Old 11-30-2008, 07:31 AM   #15
chas350
Try Vintage Chevy in Ca.
http://www.vintagechevytrucks.com/index2.html
Bill is a great guy.
chas
quote by LEEVON
70 K20 long fleet
98 G3500 work van
