Old 11-30-2008, 01:31 PM   #26
hammerdog57
hammerdog57's Avatar
Re: 55 2nd serie GMC
Thanks for the pics. Been looking for a four link kit that uses a panhard bar designed for a 10 or 12 bolt rearend. Is that rear disc brake setup aftermarket?
hammerdog57 is offline   Reply With Quote
Old 11-30-2008, 01:35 PM   #27
hammerdog57
Do you have a close up pic of where panhard bar attaches to axle housing?
Old 11-30-2008, 02:29 PM   #28
JML55
JML55's Avatar
I think, if i remember right that the kit i got came with a universal panhard bar and brackets. I would say that when ordering a kit you should be able to request the panhard bar that will fit your type of rear diff. Check their web site it shows the different types of bars. (www.heidts.com ) .
For the rear brakes i bought the caliper brackets of ebay , it comes with instruction to what other parts you need to buy to put it together. Calipers are from a 85 Cadillac Seville rear disc brake and the rotors are from 80 Camaro rear disc if i remember correctly , i would have to dig out into my paperworks to be 100% sure. I will go to the garage now and take a couple pics of the panhard bar for you and be back a little later.
JML55 is offline   Reply With Quote
Old 11-30-2008, 04:02 PM   #29
OrrieG
OrrieG's Avatar
Originally Posted by JML55 View Post
You had me worry for a second and half . But no the step side floor crossmember doesn't hit the tank filler. see picture attached.
Thanks, JM
Good, if you look at your photo the short fleetside cross rail mounts one bolt hole towards the rear to allow for the tub location.
Old 11-30-2008, 04:05 PM   #30
OrrieG
OrrieG's Avatar
Had the Belair for about 25 years now. The tank is aluminum 19 gal, i bought it of ebay ,came from CPP.
Simlar tank a little cheaper (when I bought mine, saved about $50) is availible from Online Performance.
Old 11-30-2008, 04:11 PM   #31
JML55
JML55's Avatar
Here is a closeup of the panhard bar brackets for chevy rear end.
Old 11-30-2008, 06:39 PM   #32
JML55
JML55's Avatar
Here are some pics of modification that personify this project to me. High mounted third brake light. Steering column out of a 85 Chevy van. Brake booster and pedal setup out of 99 Chevy van and a custom aluminum rad.
Old 11-30-2008, 07:02 PM   #33
56chevy1300
56chevy1300's Avatar
Nice work...thanks for the pics.
56chevy1300 is offline   Reply With Quote
Old 11-30-2008, 08:35 PM   #34
hammerdog57
Thanks for the quick pics! Just the setup i have been looking for.
Old 11-30-2008, 09:00 PM   #35
CAL 58 GMC
CAL 58 GMC's Avatar
Nice looking project man! I really like the fuel door on the fender! I also used the same tilt hood kit, man I really like it way better then the factory hinged hood.
CAL 58 GMC is offline   Reply With Quote
Old 11-30-2008, 09:24 PM   #36
JML55
JML55's Avatar
Thanks Cal 58, I appreciate the positive comments. I found that the flip hood kit took a lot of fine tunning to get it work right with my truck. The Canadien GMC truck are not built quite the same has the American ones. It also won't open as much as the Chevy one because the front of the hood hits the bumper grill bar.
Old 11-30-2008, 09:26 PM   #37
JML55
JML55's Avatar
Here is the dash. Still haven't figured out where to put high beam and signal light indicators.
Old 12-02-2008, 07:40 PM   #38
JML55
JML55's Avatar
Here some more body panel repairs.
Old 12-05-2008, 04:01 PM   #39
JML55
JML55's Avatar
Here is where i'm at now, setting up the 5.3 into my clip. Is there anyone out with this setup . 55 GMC frame with 71 Firebird clip. I need advice on engine mounts and engine location with in the clip. My fist concerns are oil pan clearance with ground, the oil pan sits about 3 inches below the crossmember, exhaust manifold touching frame rail, heater hoses outlet too close to the upper control arm. Anyone with good pictures of their engine setup. Thanks
Old 12-05-2008, 06:54 PM   #40
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Here's what I had done with my setup.
I wanted to use the original LS1 motor mounts, thus my friend made me some based on the LS1 mounts, they're the same height and width as the LS1 and welded them as far back on the K-member, what that did for me was to raise the motor up a couple inches to allow the LS1 pan to clear and also gave me more room for hearder clearance, the drawback is that I had to notch the K-member for my AC compressor but it worked out great.
Tri5
Tri5Nerd is offline   Reply With Quote
Old 12-09-2008, 12:39 AM   #41
JML55
JML55's Avatar
Here some random pictures taking over the last three years. One with the body on the original frame and an other one siting on cliped frame. See the height difference.
Old 12-09-2008, 12:42 AM   #42
JML55
JML55's Avatar
Tri5Nerd What kind of headers are you using?
Old 12-09-2008, 02:19 AM   #43
Tri5Nerd
Tri5Nerd's Avatar
The headers are PaceSetter race headers.
Here are more pictures if you want to look:
http://s4.photobucket.com/albums/y12...Chevy%20Truck/
Old 12-09-2008, 02:21 AM   #44
Kabwe
Certified Car Nut
Kabwe's Avatar
Nice project man, keep up the good work.
Kabwe is offline   Reply With Quote
Old 12-10-2008, 08:51 PM   #45
scottm
Nice looking project!
I think i've seen your 55' around at show's and the pony. Nice to see another wpg member!
scottm is offline   Reply With Quote
Old 12-11-2008, 03:01 PM   #46
bensimmons_05
bensimmons_05's Avatar
lookin SAWEEEEEEET! Maybe i missed the post, but what was the rear end taken out of?
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 12-11-2008, 09:07 PM   #47
JML55
JML55's Avatar
To tell you the truth i dont know, it came with the truck, it chevy 10 bolt 2:73 gears. I think its late 60 early 70 but not sure.
Old 12-15-2008, 10:22 PM   #48
JML55
JML55's Avatar
Too cold to do anything these days -40'c , so here is a few more random pictures.
Old 12-16-2008, 12:15 AM   #49
pugs
pugs's Avatar
its coming along nicely, gonna be a nice ride
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 12-16-2008, 08:28 AM   #50
bensimmons_05
Car bolt pattern?? Looking good by the way!!!!!
