Old 11-30-2008, 10:47 PM   #1
chev-obsession
chev-obsession's Avatar
disc brake conversion question
i have a chance to get a front end off of a 71 or a 72 chevy suburban, and this suburban has power disc brakes, and i want to put them onto my 69 chevy 2wd 1/2 ton pickup, will this work? what all will i need off of the suburban? also it has power steering too, will this make a difference? (mine doesn't) what would it take to convert that too while im at it? any input would be great!
chev-obsession is offline   Reply With Quote
Old 11-30-2008, 10:53 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: disc brake conversion question
Take all that and the rear end also( to match wheels/bolt pattern).The power steering will work if the pump brackets are from the same engine.You will want the crank pullet also.Mostly a bolt on sswap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-01-2008, 05:37 PM   #3
chev-obsession
do you know what parts i will need all together ( a-arms, spindles, calipers, etc.)
Old 12-01-2008, 05:48 PM   #4
tdave00
Restoring a 68 SWB
tdave00's Avatar
Just unbolt the entire front crossmember from the donor truck with the a-arms and everything attached and roll it out from under the truck. Then swap that into yours.
tdave00 is offline   Reply With Quote
Old 12-01-2008, 06:51 PM   #5
chev-obsession
thats a good idea. how many bolts hold it in place do you know?
Old 12-01-2008, 07:18 PM   #6
70 Suburban
Rods
If i remember 14
70 Suburban is offline   Reply With Quote
Old 12-02-2008, 01:44 AM   #7
chev-obsession
how long should it take me?
Old 12-02-2008, 01:46 AM   #8
Senator350
Senator350's Avatar
Originally Posted by 70 Suburban View Post
If i remember 14
taDAA!
RN U OVR
Senator350 is offline   Reply With Quote
Old 12-02-2008, 01:47 AM   #9
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
I don't mean for it to sound bad but start timing yourself when you start and when you finish, stop the stopwatch. Then you will know how long it took.
There isn't an answer for your question. You will run into your own unique issues pulling it apart and putting it back together again.
Take your time and do it right!
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 12-02-2008, 03:32 AM   #10
tdave00
Restoring a 68 SWB
tdave00's Avatar
Someone who knows exactly what they are doing- probably 30 minutes. Me - an hour or two .
Old 12-02-2008, 11:26 AM   #11
nightmare
nightmare's Avatar
that stuff, but don't forget to get the proportioning valve and master cylinder. disc brakes require different pressures than the drum brakes.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-02-2008, 11:36 AM   #12
my67chevytruck
Under Construction
my67chevytruck's Avatar
just did the swap about 3 weeks ago. swapping crossmembers is definitely the way to go. as nightmare and others have mentioned. get all related parts. front end. rear end. mc/booster , ps pump etc. I have pics of the xmember removed in our 67 build in my sig link.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-02-2008, 01:05 PM   #13
70 Suburban
Rods
YOU CAN USE UP TO AN 89 CHREVY FRONT END WITH X MEMEBER. THERE ARE A COUPLE OF MORE HOLES IN THE 73 AND UP BUT THERE ARE ENOUGH TO LINE UP YOUR FRONT END BOLT IT IN THEN DRILL OUT THE REMAINING INSTALL ON THIS ONLY TOOK ME ABOUT AN 1 AND A HALF TO 2 HOURS WIHT THE DRILLING BUT i HAVE IMPACTS AND BIG WRENCHES. THERE ARE A COUPLE OF BOLTS THAT ARE HARD TO BACK UNDER THE ENGINE MOUNTS BUT OTHER THAN THAT IS STRAIHT FORWARD. OHH . KEEP TRACK OF THE SHIMS AND WHERE YOU TOOKD THEM FROM
Old 12-02-2008, 02:49 PM   #14
chev-obsession
all righty, well i just wanted an estimated time, im kind of pressed for time since i get off work between 12:00 and 2:30 on the weekends and it gets dark around 4:15 and counting now days. and go to school during the week. i want to get it all at once insted of making 4 or 5 trips to get it. and i dont really want to use a 73 and up front crossmember since i know that the 71 will bolt right in without any questions.
Old 12-05-2008, 02:20 AM   #15
Jvsapp
Jvsapp's Avatar
can you elaborate on this? or do you have pics? i have a bro looking to do a brake upgrade on his 70.
Jvsapp is offline   Reply With Quote
Old 12-05-2008, 07:26 AM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Here's the skinny,
The front crossmember is held to the frame by 14 bolts, 7 per side.
The disc brake crossmember will bolt perfectly into 12 of those 14 holes. The last two holes are very close , requiring you to egg the holes a bit to get the bolts started.
I usually just bolt the 12 bolts in place to get it all lined up, and use a die grinder with a carbide bur to line the last two holes up.
Now, as far as time required,
I consider myself extremely fast at stuff like this. I did it full time for 12 years. That said, if you truck is assembled with engine and sheetmetal, you aren't going to be doing it anywhere near 1.5 hours.
The crossmember supports the engine mounts, so you will have to hold the engine up while the crossmember is out of place, either by overhead hoist, or floor jack.
Second, the engine makes access to the crossmembers infinitely more difficult.
If I was in a shop with a lift, my own tools, and air for impacts, I'd probably say I could do it in 2 hours if I was really trying to prove something or win a bet.
Your average weekend truck enthusiest better plan on a whole weekend of work because he's gonna want to clean up bolts and eat a slice of pizza periodically and enjoy the process.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-05-2008, 08:41 AM   #17
70 Suburban
Rods
Old 12-05-2008, 06:45 PM   #18
Jvsapp
Jvsapp's Avatar
Originally Posted by Tx Firefighter View Post
Here's the skinny,
so this is with a 89 crossmember and suspension parts? or with a 72? i'm trying to help my bro get his ducks in a line before we tackle this project. if its an 89 i think i might have one lined up. V6 5 speed not worth much, but good for parts. i also might have a pre 88 lined up now too. so if i can get some clarification. thanks, JD
Old 12-05-2008, 07:45 PM   #19
Tx Firefighter
The crossmembers that will work for your needs are truck 71-87 and Suburban 71-91. This is the old, square body style of truck. The trucks changed completely in 88 and Burbs in 92. So, if you're talking about using an 89 truck as a donor, you're out of luck.
Old 12-05-2008, 09:08 PM   #20
my67chevytruck
Under Construction
I agree with TXfirefighter. pull the xmember from the burb, load it up and take it with you. spray it down with over cleaner from the dollar store, let it set for several hours and powerwash it good. this is also a good time to tear it down and freshen it up (replace balljoints, tie rods, bushing , and paint) i would definitely pull the motor before i attempted this swap, but thats just me... good luck with your swap. the attached picture is what you should walk about with from the surburban as far as the front crossmember goes.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 12-05-2008, 09:31 PM   #21
AustinScott
AustinScott's Avatar
Here's the skinny,
Well stated! I agree as this is a realistic view on this topic
AustinScott is offline   Reply With Quote
Old 12-05-2008, 09:39 PM   #22
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Follow Tx's post and get to work...
Keep us posted on your progress.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-06-2008, 01:48 PM   #23
Jvsapp
Jvsapp's Avatar
thank you TXfirefighter. this will help alot. also thanks my67chevytruck for the pic. that does clarify it. exactly the same as my 77 so that will make it easier to wheel and deal.
ok second question. will this work taking a c20 to 1/2 ton? i'm hoping the bolts are still in the same place.
thanks, JD
Old 12-06-2008, 07:35 PM   #24
Tx Firefighter
Yes, it will work.
Old 12-06-2008, 09:10 PM   #25
chev-obsession
i apperciate all of the help, but i know this guy that did one before and he said that was the biggest pain in the a$$ to get that cross member in and out. he said that the frame tweaked when the crossmember was out, have you guys had any trouble with that? also if i were to go the other way... would i only need the brake booster, rotors, calipers, tie rods, spindles and proportioning valve, or do i need the a-arms too?
