Old 12-01-2008, 05:58 PM   #1
70GMCer
70GMCer's Avatar
Need Picture of Linkage
Does anyone have a picture of the original 2wd 350 turbo column shifter linkage from the trans to the frame? Also, I haven't looked under the truck yet, but is there factory holes for the trans linkage mounting bracket. The reason I ask is that my truck was originally a 3sp manual. Just wondering if all frames have those holes. thanks for any help.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-01-2008, 06:27 PM   #2
john
member #16
john's Avatar
Re: Need Picture of Linkage
Maybe this will help. Cant answer about if holes are in the
frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=316983
john is offline   Reply With Quote
Old 12-01-2008, 06:40 PM   #3
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
I donīt know what the linkage looks like for a 350 but here is the one I have on my 400.
Hope it helps a little.
The notch was cut out to make room for the exhaust.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 12-01-2008, 07:08 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I would use Lokar or Kugel Komponents linkage kit. Hassle free, easy to install, and a way better design than factory linkage. There are only 2 pivot points in it, and you will never have sloppy shifts again. Plus, if you have a 700 r4, you can dial it in so your shift indicator lines up perfectly
Old 12-02-2008, 09:26 AM   #5
70GMCer
70GMCer's Avatar
Thanks for the pics guys. That's exactly what I was looking for. I am using the Lokar linkage kit now & hate it. I've tried adjusting it per instructions & without. It never lines up to the shifter indicator & I get engine vibrations thru the column. Going to try this factory setup & see if it is any better. It worked for the GM Engineers, so we'll see.
1997 GMC Sierra Ext
1965 Mustang
Old 12-02-2008, 12:38 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Maybe Kugel is different then...I thought they were similar. I use Kugel and it took me less than an hour to install/dial it in. If you get the stock linkage to work that is great!
