Old 12-01-2008, 10:34 PM   #1
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
How many inches (bag question)
How many inches from stock would you expect to get fro this setup up front?
DROP SPINDLES, BAGS, CPP LOWER A-ARMS FOR BAGS,
Right now i have drop spindles, 3" springs and stock a-arms all around, which is giving me about 5 1/2" of drop right now. how much more lower will it be putting the bags and lower a-arms on? thanks
throw me some #s
will the crossmember sit on the ground?
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 12-01-2008, 10:53 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: How many inches (bag question)
Hey Nick. That's the front set up I have and when completely deflated, the crossmember rests on the ground. I had to install taller bump stops in case the air system failed I could still drive the truck.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-01-2008, 10:55 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Depends on your tire diameter.....my burb has 29" tires and it sits on the fenders in the front aired out and is about 1" lower than my static truck with your same set-up. Like you said, it takes $$$ and time to do the rest.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-02-2008, 08:29 AM   #4
66chevy PROSTREET
SOLD
sweet, thanks vince, got any pics of it fully deflated?
SOLD 11-29-9
Old 12-02-2008, 12:06 PM   #5
66chevy PROSTREET
SOLD
i have a about a 26'' tire up front
SOLD 11-29-9
Old 12-02-2008, 02:37 PM   #6
vin63
vin63's Avatar
My tires up front are about 26" tall and if they were any taller the inner fender would rest on top of the tire with the bags fully deflated.
I'll try and take some photos this weekend (I have to put the front suspension back together).
Old 12-02-2008, 09:34 PM   #7
protrash64
protrash64's Avatar
My static drop uses a 26" tire also. It has a couple inches clearance from the ground and a couple inches clearance in the wheelwell. Like vin63 said, that would put it on the ground with bags.
Old 12-05-2008, 11:52 PM   #8
66chevy PROSTREET
SOLD
i'm in the middle of putting in the power steering kit right now, and looking at the lower a-arms, they've been takin a beat'n. my buddies baggin his 72 stepside right now with the same setup i am wanting to go with , looks like early next year i'll be doin the same for sure.
SOLD 11-29-9
Old 01-12-2009, 09:25 PM   #9
vin63
vin63's Avatar
Hey Nick. I finally got around to pulling out all of my parts and started to assemble the front and rear suspensions - amazing what I can do now that I'm unemployed.
Anyway, here are a couple of photos of my front suspension loosely assembled. The crossmember would rest on the ground if not for the wood block - I just don't have a jack with a low enough profile to slide under the truck if it is resting on the ground. This should give you an idea.
Old 01-13-2009, 08:32 AM   #10
66chevy PROSTREET
SOLD
thanks, man, thats exactly what i needed to see. it looks killer
the fender extensions look great!
SOLD 11-29-9
Old 01-13-2009, 03:05 PM   #11
Hickup pickup
Hickup pickup's Avatar
If you want true ground clearance with maximum drop I would look at the porterbuilt crossmember!http://www.porterbuiltstreetrods.com/products.php
2-20, 2-21 whatever it takes!
Hickup pickup is offline   Reply With Quote
Old 01-13-2009, 03:13 PM   #12
joe231
joe231's Avatar
Nate even has the Newbs pushing the drop-member
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-13-2009, 05:51 PM   #13
Hickup pickup
Only a Newb here , known Nate for about 5 yrs!
Old 01-13-2009, 08:19 PM   #14
joe231
joe231's Avatar
yeah, just kinda a running joke here
Nate does some AMAZING work!
CHEVY ONLY
Old 01-13-2009, 08:23 PM   #15
Hickup pickup
No problem .
Old 01-13-2009, 09:22 PM   #16
66chevy PROSTREET
SOLD
that would be sweet, but theres no way in hell i'm pullin my truck apart for that kinda project!
i'm just lookin for a little more drop, but if i ever build another truck its getting a drop member
SOLD 11-29-9
Old 01-13-2009, 11:42 PM   #17
vin63
vin63's Avatar
... but if i ever build another truck its getting a drop member
Nick, if you or I build another V8 era truck, we are going to use some of my chromoly tubing to do this...
...and then this...
...then we're going to do what Chris did...wait for it
...I just don't think a drop crossmember will be necessary.
Old 01-14-2009, 08:09 AM   #18
66chevy PROSTREET
SOLD
...and then this...
exactly
SOLD 11-29-9
Old 02-24-2009, 11:00 PM   #19
66chevy PROSTREET
SOLD
i used some chassis tech arms i got on this forum for a good price. when the bags are deflated the inner fenders sit on the tires, and the front tube on the lower a-arm sits on the ground. i think the crossmember would sit on the ground if the tire would be able to go up higher. the benfit of these arms is that you run a full bag at ride height.
SOLD 11-29-9
Old 02-24-2009, 11:06 PM   #20
protrash64
protrash64's Avatar
On the 'spindle debate' thread a guy posted saying his truck set the X-member on the ground with a 26" tire. You must be a little bigger; my 20's hold the front off the ground.
Post up a pic, I'd like to see.
Old 02-24-2009, 11:14 PM   #21
66chevy PROSTREET
SOLD
will do,
but i think its the design of the lower a arm that is the reason. look at the way vin63's CCP arms are made compared to mine.
SOLD 11-29-9
Old 02-24-2009, 11:17 PM   #22
protrash64
protrash64's Avatar
Your pic came up after I read your post! Well, looks clean ..good job. Lets see it aired out.........
Old 02-24-2009, 11:31 PM   #23
66chevy PROSTREET
SOLD
this is with the fender raised off the tire about 1/2".
SOLD 11-29-9
Old 02-24-2009, 11:38 PM   #24
protrash64
protrash64's Avatar
Looks cool dude....... Always nice to finish a successful project!!!
Are you running a stop anywhere? I dont have one but need to get one in there somewhere.
Old 02-24-2009, 11:45 PM   #25
66chevy PROSTREET
SOLD
no, not yet, i have not road tested the setup yet, i had to change my headers to some mid lengths,and i'm not yet installing them yet, and i have to finish with some sheet metal work also, then run new pipes. i will install some bump stops somewheres though.
SOLD 11-29-9
