Old 12-02-2008, 08:49 AM   #226
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Killer
Bags are bottoming out and im running stock spindles with a 1 1/2 sectioned crossmember. Looks like imma order some drop spindles thanks matt thread hijack over..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-02-2008, 01:23 PM   #227
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
No problem
I dont know what wheels you are running, but I have read that 3" drop spindles wont work (or at least not W/O mods) with 15x8" wheels
I bought the 2-1/2" DSs & mine are pretty close
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-02-2008, 09:40 PM   #228
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
Well I checked the mail today & I got my new rear view from Mekdad
What it looks like out of the box
Not bad, but has VERY sharp edges & slight machining marks
So I smoothed the edges with a orbital sand & uses 220 grit
Then I hand sanded it with 600 grit
Then I polished it on the buffer
Sinister
Killer
Old 12-02-2008, 09:41 PM   #229
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
Some installed pics
Shiny huh
Sinister
Killer
Old 12-02-2008, 09:45 PM   #230
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
I also worked on the heater box some more, but didnt get it finished
And I took some more pics of it at dump... Mainly cuz Im pic whore
In some of teh pics below the front tires are sitting on some 2" thick boards because the LCAs dont slide on the cement very well & wont let it lay 100% out, so with the boards under the tires it actually lays out a half inch lower than without (5" to the bottom of the bumper at the lowest point W/O the boards & 4-1/2" with the 2" boards under the tires)
Nighty Night Killer
Sinister
Killer
Old 12-03-2008, 10:37 AM   #231
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: Killer
Cool! How you think that mirror bracket would look painted black? I want mine to look as stock as possible and the polished aluminum just doesn't look stock to me.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 12-03-2008, 11:02 AM   #232
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Re: Killer
Mirror bracket looks great.
At dump now, what is the distance to pinch weld?
What will crossmember to pavement clearance be at ride height?
What length shocks will you need or are you going to mod the brackets to run stock?
Is this where you plan to leave the front suspension for a while, at least til you get a drop member? Or do you have other mods planned for it?
Looks really good.
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 12-03-2008, 02:32 PM   #233
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
Looks really good.
Well I did have a ex chrome shop owner to teach me
IIRC its about 3" (the middle of the front bumper is 5")
Im not sure of that, but thats not what I have to worry about, my LCAs are the lowest part of my scrub line
I still need to measure & see how long they need to be
Yeah this is as low as Killer 1.0 is going
Although I may pie cut my UCAs to help with camber
Sinister
Killer
Old 12-03-2008, 02:46 PM   #234
BACKYARD88
BACKYARD88's Avatar
Re: Killer
I've been considering the very same thing
-Mike Owen-
Old 12-03-2008, 03:15 PM   #235
69Rob
69Rob's Avatar
Re: Killer
No problem
Hey bomb just wondering why wont the 3" drop spindels work? i have a disc setup out of a 81 and i was going to order the 3" spindels any info? On my member i plan on using a couple drag blocks and jsut bolt it to the bottom of the member not sure if that will work but it seems good in my head.
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 12-03-2008, 03:22 PM   #236
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
They make the LCAs REALLY close to the wheels & the more inset the wheels have the worse it is (only with 15" wheels, anything bigger is just fine)
Now I have heard of some people clearancing the LCAs so they dont rub or knock off the wheel weights, but I have never done it
In the end it only matters how low you want to ride & its only a 1/2"
My truck would lay out just as much in the front without them, but it had STUPID camber & to get rid of the camber I had to air it up a lot
Sinister
Killer
Old 12-03-2008, 04:52 PM   #237
69Rob
69Rob's Avatar
Re: Killer
ok then ill be ok ill be runnign 20's up front and 22's in da back thanx for the info and that truck is looking nice
73 2 door nova
54 bel air
Old 12-03-2008, 07:27 PM   #238
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
I really didnt get anything done to Killer today... but I did stare at em, does that count ???
I mocked up the heater box & I think Ima have to cut the corner of it a lil more for more clearance
It clears the tire, but it wouldnt allow for a inner fender
I will be filling in the stock hole & making a tube that runs into the inside of the cab... A sort of bulkhead I suppose
Also found out that at true full dump, my tires come off the ground
Sinister
Killer
Old 12-04-2008, 05:43 PM   #239
BACKYARD88
BACKYARD88's Avatar
Re: Killer
That's sweet!
-Mike Owen-
Old 12-04-2008, 08:22 PM   #240
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
I thought so
Sinister
Killer
Old 12-04-2008, 11:46 PM   #241
joe231
joe231's Avatar
Re: Killer
what is the truck resting on when the wheel is off the ground?
pretty cool!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-05-2008, 12:24 AM   #242
19gmc67
19gmc67's Avatar
Re: Killer
cant get no lower than that
19gmc67 is offline   Reply With Quote
Old 12-05-2008, 12:45 AM   #243
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
Thanks guys
Its resting on the LCAs
Actually you can, but its a lot more work & money
Sinister
Killer
Old 12-05-2008, 02:05 AM   #244
72hotrodder
THE TOY STORE
72hotrodder's Avatar
Re: Killer
hope you dont plan on drag'n it. scarry to drag and not be able to atleast stear a little bit
72hotrodder is offline   Reply With Quote
Old 12-05-2008, 02:32 AM   #245
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
I wont drag it much & I will have drag blocks under it
Sinister
Killer
Old 12-10-2008, 05:16 AM   #246
chevychase
chevychase's Avatar
Re: Killer
Great work on this build! How about the pie cut on the UCAs you mentioned earlier to help with camber issues. What's involved or whats the general procedure?
chevychase is offline   Reply With Quote
Old 12-10-2008, 12:32 PM   #247
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Killer
I havent done that yet, & I was mistaken on what it does... It helps with BJ bind, not camber
Sinister
Killer
Old 12-13-2008, 01:26 AM   #248
ShowSS12
ShowSS12's Avatar
Re: Killer
YouTube - Killers wheel
Thats awsome
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 12-13-2008, 01:53 AM   #249
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: Killer
Hope you don't ever need to turn when dropped... lol
killer ride.
texanidiot25 is offline   Reply With Quote
Old 12-15-2008, 04:16 PM   #250
63 & 64 Bowties
and a few others
Re: Killer
back on page 7 where your dad's holding the fender in place, is that at ride height, or are the bags dumped, or are the bags in yet? will it go lower than what is shows in that pic?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
