Old 12-02-2008, 08:29 PM   #1
m6z
m6z's Avatar
Replacement Brake lines ?'s disc/disc
I've got a 68 swb that's been converted to 4 wheel disc brakes. I's there any perference as to what year brake lines/master cylinder to order?
I've read that you can use the distribution block used on all 67-70 trucks, so if I just order the same year distribution block as brake lines & order a disc/disc brake master I should be good to go right? Any preference on which master to use?
Also read that a mid/late 70's corvette disc/disc master is the way to go. Adj. porp valve has also been recomended?
So vette master with a adj. prob. valve or just use the stock distribution block?
Going to replace all brake lines and the master/booster. What the hell should I buy? It seems there's quite a few ways to go with this.... I'm not so good with makeing decisions..............lol.
m6z is offline   Reply With Quote
Old 12-02-2008, 10:26 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Replacement Brake lines ?'s
Just get this and be done with chasing parts......
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-03-2008, 10:07 AM   #3
m6z
m6z's Avatar
7956 7" Dual diaphragm Bendix Booster/Master Combo, Disc / Disc 48 $345
That's not to bad a price. Thanks for the help.
Old 12-03-2008, 08:48 PM   #4
Sport/Truck
Sierra Grande Club
No, no, The top one is the one I'm eyeing! It's a power unit and needs no booster!
s/t
Old 12-03-2008, 09:33 PM   #5
8mpg
8mpg's Avatar
s/t
how much is it?
8mpg is offline   Reply With Quote
Old 12-04-2008, 01:26 PM   #6
chris71
chris71's Avatar
those look like good kits, because they are designed for 67-72 trucks apparently. you have to know what you are doing when you mix and match brake parts from different vehicles, like that vette MC. the mc is essentually designed around the rest of the braking system. different calipers have different flow and volume requirements. a single piston caliper has a different fluid volume requirement than a 4 piston. so if you are putting a vette mc on a 67-72 single piston type caliper for example, dont be too surprised if you run into problems. C3 vettes run 4 piston calipers on all four corners. the bore size of the mc as well as the resivoir size controls volume/flow. brakes are the one thing on the truck you dont want to screw up. if this was my project i would call this company, speak to a tech guy, explain to him what brakes you have, and see if what you are interested in as far as a mc/booster will work for your application. you can also ask him what prop valve he would reccomend
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 12-04-2008, 02:13 PM   #7
Sport/Truck
Sierra Grande Club
[QUOTE=8mpg;3007079]how much is it?[/QUOTE
It's on sale @ $600.
s/t
