3 speed column to 4 speed floor
I don't know much of anything about the 55-59 trucks. I was wondering what would be involved in changing the column shift to a floor shift. Is there a removable floor hump section? Also are there any late model overdrive manual transmissions that would bolt in relatively easy?
Re: 3 speed column to 4 speed floor
what motor do you have? t-5 is about the easiest swap. do a search been done many times.
I am looking at buying a 59 with a 235 and 3 speed column shift.
![]() Join Date: Oct 2007
they make a kit to change the three on the tree to a 3 on the floor kit. i think hurst makes it and it is fairly cheep too. might be b&m.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
Hurst
I have used swap meet 4 speed shifters and only used the ones for the two arms and not the reverse so your options are open, If the gear box is bad you may look into a saginaw camaro 3 speed it should fit right in place of your 59 3 speed box. you have many options by not having a rear crossmember to worry about
My experience with transmission swaps is you may run into problems with tail-shaft length. And the transmission crossmember. Of course, the driveshaft can be shortened and the crossmember modified or changed.Then worry about a shifter.
Does your truck have the rear motor mounts on the bellhousing?
I haven't looked at the truck in person yet. So I have no idea what it looks like underneath.
Thanks for all the info eveyone! |
a muncie or Warner T 10 or super T 10 should be pretty much a bolt up
and you can buy a hurst shifter stick with a bend to clear bench seat makes for a fun driveable package and with a highter geared rear you can use 1st three gears around town and 4th on the highway If you do a V 8 swap a v 8 bell housing for the early years will let you retain stock cross member and clutch and everytihng hooks up Gene Sharp |
![]() Join Date: Sep 2008
Mr Gasket makes a pickup truck 3 speed floor shift conversion kit for Chevs part # 7667A. Just put one in my sons 67 C-10 was easy to do. Purchased it at Ato Zone for $69.99 plus tax. Hope this helps you
Yes it does. I am definitely not liking the column shift. I was considering a stealthy automatic conversion, but that is kind of difficult with the 235 6 cylinder. Before I take the V8 with Auto plunge I may try a floor shift conversion.
