Old 12-03-2008, 05:51 PM   #1
turbotank
turbotank's Avatar
spring length
I have two questions, is the 3/4 ton springs the same length as the 1/2 ton springs?
What is the trick to getting the front bolt out on the springs,how do you get a wrench in there?
The general is always in charge
You guys did this to me!!!!!!!!!!!!!!!!!!!!
turbotank is offline   Reply With Quote
Old 12-03-2008, 07:49 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: spring length
No 3/4T springs are longer than standard 1/2T springs. They are the same as HD springs on a 1/2T though.
IF the bed is on the truck, it will be an experience, but it can be done.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-03-2008, 10:04 PM   #3
turbotank
turbotank's Avatar
Re: spring length
so would you have to move the spring hangers to get the 3/4 ton springs to work in a 1/2 ton suburban?
Old 12-03-2008, 10:14 PM   #4
tgh117
Crazy
tgh117's Avatar
Re: spring length
Since I just took all the springs off my truck I have just been in the same experience. I took a sawzall and cut both sides of the bolt from underneath the spring hanger. Was the only way I was going to be able to get it apart. I didn't care that much because I was swapping all new springs in, so I just wanted them out of the way.
Also, I don't know the length difference between the springs, but if they are fairly close you may be able to take up a little extra length with just the rear shackles, but again I don't know what the difference is.
Good luck with your swap.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 12-03-2008, 10:59 PM   #5
turbotank
turbotank's Avatar
Re: spring length
No,don't really wanna cut em off,no money to replace!
Old 12-04-2008, 03:29 PM   #6
Captkaos
Captkaos's Avatar
Re: spring length
Don't quote me on this, but all of the Suburbans I have owned and seen came with the 3/4T springs. They are 56" long (30" from the bolt to spring eye). Might measure yours to verify.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-04-2008, 04:50 PM   #7
turbotank
turbotank's Avatar
Re: spring length
They might come with the hd springs,but just with a visual comparison,I can tell you that there are about two or three springs less on the suburban.I think that I am going to keep them though,cause most of my weight will be a on a trailer,it being a suburban,to only the tongue weight should come into play,and I want it to still ride nice.
Old 12-05-2008, 05:54 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
Re: spring length
How many leafs are on these Suburban rear springs ?
Reason I ask is, I have the HD springs on my truck. It originally had 8 leafs with a HUGE helper spring and the ride was awful. I pulled identical leafs out on each side but the end result was not equal.
If these Suburban springs are softer than the 3/4 ton springs, they might be good for trucks with HD springs that need a softer spring.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-07-2008, 02:03 PM   #9
turbotank
turbotank's Avatar
Re: spring length
Yeah I think they only have like 5 leaves in them,but I will check for you when I get a chance.
