Old 12-06-2008, 02:14 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Thoughts on ride height???
Im needing to set-up my watts link but need to figure out my ride height. So guys whats the best way of doing this I am still needing my drop spindles do I need to wait or can I set-it up now? Right now I am running 15 wheels and tires but am gonna step up to 20''s do I need to take that into consideration? Any helpful info or insight would be great..
set-up I have now consists of
front
stock 72 spindles ( soon to be ordering 2 1/2 drop spindles)
strong arms
firestone bags
1 1/2 drop crossmember
rear
2'' blocks
bags are on order but will mount to the trailing arm
flipped center crossmember
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-06-2008, 02:17 PM   #2
Twisted Minis
Twisted Minis's Avatar
Re: Thoughts on ride height???
So you plan on bagging the back? I prefer to set them up at half travel. So if you get 8 inches of lift, set it up at 4 inches.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 12-06-2008, 02:40 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
You should set the rear suspension where it will be at ride height. If you are using a 7" diameter bag(RE7,2600) installed bag height will be ~6". Stick a temporary spacer(block of wood, etc.) at your desired installed spring height on top of the trailing arms and rest the frame on them. Build your Watt's at this height. Tire diameter will not affect where your suspension is at ride height-only how far your frame is off the ground.
While your air suspension is adjustable, to function properly, it will need to operate within the manufacturers installed parameters. So, basically, you can set it up as though it were static. Clear as mud?
Side note- What Watt's set-up are you running?
- Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-06-2008, 02:45 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
The re7's are the bags I ordered as far as the watts link it is part speedway part home brew from looking at others on the board. Do I not need to pay any attention to fron camber toe in toe out etc etc?
MEMBER #6377
Project "7DEUCE"
Old 12-06-2008, 03:07 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Yes you do, but it should not affect your rear suspension height. For mock-up purposes, you could set your front suspension up at current installed height, then deflate 'til you're 2.5" lower. That way, everything is as it will be at ride height. There is quite a bit of adjustment for camber at the upper a-arm mount, so you should be OK there.
-Chris
Old 12-06-2008, 04:54 PM   #6
lowestsixty7
I agree with Twited Minis....that is basically the way we will set them up too.
lowestsixty7 is offline   Reply With Quote
