Old 12-06-2008, 04:43 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
Stock CFM?
What is the stock CFM on the 4 barrel carbs in the 79s on the 350s?
What is the lobe on a "RV" Cam too?
Benelli is offline   Reply With Quote
Old 12-07-2008, 12:37 AM   #2
slugish
Slugish
Re: Stock CFM?
Im not an expert but Ithink most of the 350,s during these years came with a 750 cfm quadrajet carb (Rochester)
RV CAMS provide good torque with a duration around 212 - 218 & a lift of .o45 -.o46 range. The main advantage of these cams is torque PULLING POWER ) with a decent increase in horsepower .
slugish is offline   Reply With Quote
Old 12-07-2008, 03:02 PM   #3
worthirt_99
worthirt_99's Avatar
Re: Stock CFM?
If you are going to get a new carb, you should only need about a 625-650CFM. Slugish is right on about the carb, but that carb came on about everything that GM made. I believe the the 454 is included in this. The Q-jet basically is "tuned" for your application and will only run what is needed CFM wise.
worthirt_99 is offline   Reply With Quote
