12-06-2008, 07:44 PM | #1 |
Lowering Questions
I already have drop spindles, 1 in. drop springs and 4 in. drop rear springs, but I want to go lower, and don't want to keep buying springs. Can I cut a little piece of the first coil off to get the equivalent of another inch all around? I know cutting springs isn't the best but I don't have budget to buy different ones.
12-06-2008, 07:55 PM | #2 |
WTB:Patience and Talent
Re: Lowering Questions
I have done it but it's easy to miscalculate. I recommend cutting less than you originally expect. It changes more than you think. I was messing around with my front springs because I am bagging anyway, I cut what I thought would be 2" drop. Ended up about 4" drop resting on bumpstops! Little at a time and you should be ok.
69 shortwide |
12-06-2008, 08:02 PM | #3 |
PROJECT 7DEUCE
Save your money and buy the bags I was once where your at.... Now im here..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-06-2008, 08:39 PM | #4 |
Wow FRENCHBLUE that looks awesome. I don't have the coin to bag right now, but I would love to someday. I like the license plate hanging sideways.
12-06-2008, 08:39 PM | #5 |
If I do cut, what do I use?
12-06-2008, 08:56 PM | #6 |
PROJECT 7DEUCE
Thanks and you can use a cut off wheel on a disk grinder just put one end of the spring in a bucket of water.
12-06-2008, 09:04 PM | #7 |
Why the water?
12-06-2008, 09:15 PM | #8 |
PROJECT 7DEUCE
Keeps the spring cool.
12-07-2008, 03:11 AM | #9 |
Alright makes sense. Thanks
12-07-2008, 11:19 AM | #10 |
Too many toys,not enough money
I just did this on the front of my 71. One coil cut off will get you 2" to 2 1/2". I used a chop saw and cut right through it.
12-07-2008, 01:08 PM | #11 |
OK so 1/4 to 1/2 a coil should give me around 1 inch
12-07-2008, 03:06 PM | #12 |
The bucket of water trick is only needed if using a torch to cut the spring. If you use a cut-off wheel, the heat is much more confined to the immediate metal & cooling-water is not req'd.
12-07-2008, 03:32 PM | #13 |
Ok cool
12-07-2008, 06:12 PM | #14 |
Hey, check my thread in the suspension forum "easy way to R&R front coil springs". There is some good info in there on cutting coils. I also have a before and after pic in there. As for how much coil to cut to get 1" of drop, I think "The Shane, the moderator" is the guy to ask. I was surprised how much 1 coil dropped the front.
12-07-2008, 06:35 PM | #15 | |
67-72 parts collector,…
Up front,... a good rule of thumb is,... 1/2 coil = 1 inch of drop. In the rear,... you can't cut the coils because the ends of the coils are a smaller diameter than the middle of the coil. Just add the correct size lowering block. 1", 2", etc.
12-07-2008, 06:41 PM | #16 |
Are lowering blocks cheaper than a new set of springs? And where do I find them
12-07-2008, 06:42 PM | #17 | |
Yes I would like to drop another inch front and back, so it becomes a 4/5 drop |
12-07-2008, 07:03 PM | #18 |
You can buy them,... but look here,
http://67-72chevytrucks.com/vboard/s...d.php?t=196457 and make your own. Longer u-bolts usually run about $25-$35. I haven't priced aftermarket blocks lately. Also,... the FAQ section is full of good threads. http://67-72chevytrucks.com/vboard/s...d.php?t=262550 That's where I found this "lowering block thread". Save the FAQ section in your favorites,... you'll be surprised how often you look there and find answers!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-07-2008 at 07:04 PM. |
12-08-2008, 02:57 AM | #19 |
Looks great, is there somewhere I can buy longer U bolts? And not have them made?
12-08-2008, 07:28 AM | #20 |
Companies like CPP sells lowering blocks with longer u-bolts. Also search "u-bolts" in the suspension section. It's been talked about just recently.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-08-2008 at 07:30 AM. |
