12-08-2008, 07:17 PM | #1 |
WTB GM vortec intake bolts
Want to buy a set of 8 GM Vortec Intake bolts..SBC
Let me know what u got.
12-11-2008, 01:36 PM | #2 |
Re: WTB GM vortec intake bolts
I don't have any, but just got done putting a hybrid TBI intake onto a Vortec motor. FYI, there is nothing special about the bolts, unless you are going for the "stock" look. They are 5/16" diameter. I forget the length, but it seems they are about 1 1/2" long. I pulled the stock bolts out and used longer bolts to attach the engine to the lift when i put the engine in. A hardware store should have them, or GM parts. I could imagine that GM will be high $$$ though.
12-17-2008, 02:31 PM | #3 |
yes.. you are "right on the money"
in more ways than one.... the bolts are plain... i ordered some from GM... the counter guy let me see them...didnt buy them. i got some from my NAPA store.. GM lists for $5.00 and some change for each.. EACH bolt... grrrrr. thank you for your input.
12-22-2008, 04:57 PM | #4 |
They come with sealant applied to the threads dont they? Also dont for get the 11 lb/ft torque spec.
New GM gaskets(ones with the metal anti crush tabs) or the FelPro problem solver gaskets are the way to go. Goodluck peace Hog |
12-27-2008, 05:05 PM | #5 |
Hog, yes, thank you.. good info
12-28-2008, 01:00 PM | #6 |
Just order the ARP ones. Better quality and cheaper then GM. Check at your local speed shop for p/n 134-2002 for the factory look ones. 12 point and stainless are also available
And yes, use the Fel Pro Problem Solver p/n MS-98000T gaskets. They will save you a real issue down the road.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now). 95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver |
