Old 12-09-2008, 12:20 PM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Wanted... 3.42 gears and posi
Need a set of 3.42 gears and a posi unit for my 72. A rebuildable unit would work fine. Not trying to break the bank right at Christmas so take it easy on me fellas.. Thanks
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 12-10-2008, 03:14 AM   #2
71chevytruckguy
71chevytruckguy's Avatar
Re: Wanted... 3.42 gears and posi
i've got a set of 3.42's that came out of my '69. nuttin wrong with them but, 2 little chips off the inside of the ring gear, should be fine. ill take $40 for them if ya come get them. can post pics if you're interested. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 12-10-2008, 09:14 AM   #3
STOCKISH
STOCKISH's Avatar
Thanks but I would like to find a set already with the carrier if possible. Thanks again.
--Josh
