Old 12-10-2008, 10:57 AM   #1
BenU
BenU's Avatar
I got a Rust Problem
above the winshield on the inside there is a lot of rust on every cab that i find around here in the northwest. All the rust forces the seal down and you can see all the rust. On most of the Trucks i can take a screw driver and push it through the metal right above the review mirror on the inside. I was wondering if that was ablt to be fixed by putting in a replacement part or just with a little bit of work. Or am i going to have to send it to a body shop to have somebody do it for me.
thanx, Ben
BenU is offline   Reply With Quote
Old 12-10-2008, 11:21 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: I got a Rust Problem
You must be on the ocean side of the mountains up there.
They do make a repair panel that will fix you up, on the inside at least. How is the cab on the outside?
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-10-2008, 11:31 AM   #3
monte0185
monte0185's Avatar
Mine has the same issue in the corners. They do make a repair panel for the insde per above but i have not tried the repair. Waiting for some warmer weather. Hope you get yours fixed. Good luck.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 12-10-2008, 11:53 AM   #4
Livrat
Member #1049
Livrat's Avatar
It can be fixed but it is a major repair. To me, unless you are up for cutting, grinding and welding it would easier to find another cab.
I would head a little bit inland and you should be able to find you a cab that does't have that issue..
I am just south of Seattle and just accasionally find them rusted in the upper windsheild area. so good ones are out there but will admit you probably will have to check out more that a few..
If I can help you out in any way shoot me a message.
Livrat is offline   Reply With Quote
Old 12-10-2008, 12:03 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I don't know what metal the repair part comprises, but the part is out there for those who need it. How is the rest of the cab? Does it have anymore issues that you know of? How about the cab corners, kick panels, rockers, the extensions at the bottom of the door posts? If all of this is good, then it may be that you just need to belly up and get to work.
On my cab, we're going to have to cut the windshield posts in half, then cut the cab across the floor, from door sill to door sill and that's just to replace the firewall. Except for the posts, nothing will be visible to the unsuspecting eye.
A plasma cutter would be a great thing to have at your disposal, huh?
Check Tri-Pro Automotive. They're located in New Jersey, but they have all kinds of rust repair parts. There should also be someone closer to you than they are, but I don't know who it is. We have a vendor in your area, too. He (Wes) has all the answers to your many questions.
Member Nr. 2770
Old 12-10-2008, 12:44 PM   #6
BenU
BenU's Avatar
Do you know what company has one of those repair patches for around the winsheild. I am looking for one that is fairly local to us.
Old 12-10-2008, 12:49 PM   #7
BenU
BenU's Avatar
hey livrat, do you know where i can get one of those repair panels for around the winshield. I am looking for a fairly local company. I have a cab that doesn't have rust around the winshield, but it needs floor, rocker, and inner rocker panels
Old 12-10-2008, 01:09 PM   #8
Livrat
Member #1049
Livrat's Avatar
There are a couple of vendors that are fairly close.. either PICKMUP (Frank) or Classicheartbeat (Wes), both are in olympia.
Or take a peek at the vendor list on this site and possibly find someone closer to you.. I am not familiar with anyone north of me who may able to help you out..
Old 12-10-2008, 01:23 PM   #9
BenU
BenU's Avatar
does pickmup or classicheartbeat have websites that i can look at, or some way of getting ahold of them so i can find out a price and exaclty what the dimensions of the patch are.
Thanx, Ben
Old 12-10-2008, 01:56 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Click on the "Vendors" on the homepage. Scroll down until you get to one you want to know more about, and that will be all you need to do. So, yes....they have websites.
Member Nr. 2770
Old 12-10-2008, 02:00 PM   #11
caminokid
Chevy nut
caminokid's Avatar
I have rust problems too in that area. But i am going to switch roofs on my truck. The stepper is just starting to. So I have a cab that everything else is rust except the roof.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
