12-10-2008, 08:47 PM | #26 |
I'm a poor spectator
Re: Frame Sag
Did you put something like these on it??
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
12-10-2008, 09:22 PM | #27 |
Re: Frame Sag
yep, they are the polyurethane red mounts, cant remember the name of them, but they also make the stops and bushings for leaf springs etc., yep that was the first thing i checked to make sure they were the right height etc., any ideas to stiffen up the frame/body?
12-10-2008, 09:23 PM | #28 |
Re: Frame Sag
yep, thats them the energy ones.
12-10-2008, 10:46 PM | #29 |
Re: Frame Sag
If you used the new mounts at the time of your build shimming is the way to go. I wld suggest loosen your body mounts in the area that you are trying to fix and start jacking up the body from the middle of the truck with a 4x4 spanning th rocker boxes til your lines are where you like them and then fill the gaps on the body mounts with shims and you're good to go. Hope that helps. Mario
12-10-2008, 10:51 PM | #30 |
Re: Frame Sag
If you're going to add more shims, or adjust some, I'd recommend loosening all the body mounts on the tub. Otherwise you can cause some binding. It's a very tedious process.
12-11-2008, 06:55 AM | #31 | |||
Re: Frame Sag
Everything your describing suggests your body mounts are not correctly adjusted, either not torqued enough, not shimmed enough or could even be torqued to much or shimmed to much. Also, the torsion boxes ARE what's meant to keep the tub rigid in the door area, that's exactly what their there for, pull the rear cover off and check em out. How are the lower 'A' pillars looking? Is there any noticeable rust on the tub? Keep in mind that these frames are designed to flex, have you compared it to another one to see if there's any differences? Pics of a "good looking" lower 'A' pillar for ya. #1 - looks pretty solid #2 - ...guess not after all. #3 - Here's the internal support system, it isn't your door openings sagging, it's your firewall moving/flexing here. |
12-11-2008, 09:49 AM | #32 |
Re: Frame Sag
12-11-2008, 12:56 PM | #33 |
Re: Frame Sag
I have this same problem with my '72, but I haven't taken it apart yet to investigate the issue. I've read several threads about this issue, and everyone always says shims will fix it. They are probably right, but I don't know for sure. This link to a similar thread might help.
http://coloradok5.com/forums/showthr...Y+MOUNT&page=2 |
12-11-2008, 01:33 PM | #34 |
Re: Frame Sag
Same only different...
12-11-2008, 04:45 PM | #35 |
The LuvShack Garage
Re: Frame Sag
If they are aftermarket this could be some of the issue, I had this problem.
12-14-2008, 07:40 PM | #36 |
Re: Frame Sag
anybody know where to get those little striker plates (chrome blocks) at the top of the doors
12-14-2008, 08:30 PM | #37 |
SKINNY TIRES RULE!
Re: Frame Sag
Repops aren't made. You'll have to start searching for used ones. If you become a subscribing member, you can post a "wanted-to-buy."
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
