Too many toys,not enough money
Tips on how to get rusted u-bolts out of trailing arms needed
I tried a search about this but came up with nothing. I'm in the process of adding a lowering block to my 71
Re: Tips on how to get rusted u-bolts out of trailing arms needed
try a nutbreaker. Has worked well for me in the past, about $12 at local auto parts store
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
sharp as a marble
![]() Join Date: Jan 2007
I had a similar problem that I cured with a torch. Heated up the control are, and made the rust unhappy. I had put the nuts back on, and smacked the nuts with a BFH. IF you do not have access to a torch, might cut the ubolts off, remove the control arms and take the arms to someones torch.
Im not sure what a nut breaker is exactly. I do have the bolts off, if thats what it does, it's the shaft of the u-bolt that is stuck.
I just went and had a delicious ![]() ![]() My darn "easy button" never seems to work. |
sharp as a marble
if the threaded ends of the ubolts are already buggered up, and you have the torch hot. heat up the control arm, get it nice and red, and the get the BFH, and hit it like it like ya mean it. Try and drive it out a bit, and then drive it back in as a means to loosen up the rust
OH YEA buggered up is a southern term. kinda like FUBAR Last edited by cparman; 12-10-2008 at 08:52 PM. Reason: spelling andy |
Resident of Here
I used a grinder and a hammer and WD-40.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#7 | |
#8 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Why? There is nothing critical on that end of the arm that heat would damage. If you heat the arm good and warm and thump the stub of the u bolt, it will eventually move.
#9 | |
I can learn, thanks for your expertice!! ![]() |
I just went through this last week. I used a cold chisel to spread apart the trailing arm to loosen the pressure on the u-bolt. I then used a sledge to hit on the trailing arm around the u-bolt. Take care to not hit too hard as you will dent the trailing arm. use force as you deem fit, but be careful! Then use the cold chisel around the u-bolt and you should be able to get it to break free. took me and a buddy about an hour of manipulating to get it to pop out.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
senior member
have u tried a floor jack under the portion that is still coming thru and using the weight of the truck to help?? i used to do it all the time on forklifts and it worked great
69 GMC bagged |
instead of oil trying to squirt vinegar down the remnant of the ubolt will help disolve the rust
#13 | |
Irishpilot, I think thats my next plan, remove the trailing arm and give it a go! Thanks. |
Junior Member
heat it mildly a few times and quench with a good penetrating oil. If that doesnt get it... you will need to get the dude hot hot and throw the smack down with a good deadblow ( regular framing hammers need not apply). If you get it red hot... do not quench it. That will harden the steel and make it brittle. If you heat it to much you will anneal the metal but in order to do that with a propane torch you will be there for a long time
#15 |
Its Deja Vu time again
I just cut the U-bolt on both sides of the axle removeing the arch. Give the bolt a good drink of PB blaster or your favorite penatrating oil. Try and twist the remaining bolt turning on the nut back and forth some the remove the front bolts from the cross member so you can remove the control arm with bolts in tact.
![]() Flip the control arm over so the top of the bolt is pointing down to the ground. Give it a few wacks try and turn with the nut again and give it a few more wacks and the bolt will push it self through. |
#16 |
Heat up the bolt and pour brake fluid on it. Works everytime.
I've also used candle wax instead of brake fluid. Mick |
#17 |
i keep a bottle of Iodine in my toolbox. its cheap from rite aid and works better than penetrating oil.
www.cardomain.com/id/pooz911 |
#18 | |
One day...
![]() Join Date: Apr 2008
#19 |
Thanks for all the tips guys! Finally got it out out on Tuesday. I"m not sure what exactly worked the best, I had it sitting in penatrating oil for a while, tried heating and dumping brake fluid on it, poured vineger on it. I was at the parts store, getting rags and a new 1/2" ratchet (broke it trying to get the u-bolt nuts off) so i bought a new bigger BFH, and saw a pipe wrench there and a light came on! So I clamped my 18" pipe wrench on it, gave it the size 11 and it slowly started to turn!!! Finally progress, so I broke out the new BFH and wala, one stubborn 1/2 of a u-bolt in my hand!
So now my question is. Can a u-bolt feel pain? I think i'm going to get midevil on this thing! Payback is priceless. |
