02-26-2003, 07:50 PM | #1 |
i love summertime
lowering a leaf rear
who hear has a leaf rear lowered, whats the cheapest way to do it, the axel is below the leafs so i cant use blocks.....any ideas would be great..and the cheapest ways are the best
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
02-26-2003, 07:59 PM | #2 |
PROJECT 7DEUCE
How low do you wannna go ??????Axle flip kit would be one way but if you dont wanna go that low get dearched springs ..Just my 2 cents
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-26-2003, 07:59 PM | #3 |
Fabricate till you "puke"
How far do you want to drop it?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-26-2003, 07:59 PM | #4 |
How low do you want to go ? I d say get them De-arched Cheep like under 50 bucks our money you can get like 5 inches of drop if you want.I dida 3" spring de arch and a 2" drop Shackle If I need more drop I can take them out and have more drop for another 40 bucks. I had new bushing U bolts and the spring work done for 100 bucks CDN.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 02-26-2003 at 08:02 PM. |
02-26-2003, 08:30 PM | #5 |
i love summertime
Well the front is lowered 3" allready, i wanna see how it sits with the body first, because i know the back are sagging a bit, hell maybe there will be enough sag and it will sit nice..thanks for the ideas guys
02-26-2003, 09:01 PM | #6 |
Got 20's????
Do what I did the first time around and just start pulling them out until it sits nice, but then you get wheel hop when you do burnouts.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
02-26-2003, 10:14 PM | #7 |
Location: Bondurant, IA but in Worcester, MA for school
72chevyLWB - how many leafs would you remove to get a 3"-4" drop in the back? Also if you got traction bars would that fix the wheel hop problem? Thanks
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
02-26-2003, 10:17 PM | #8 |
14.1 @ 96MPH
You can buy 4" drop leaves or 1.5" drop shackles (or both, though a flip kit would probably get the same drop for much less) or get the springs de-arched.
Project1970 - LS1 Swap Complete! |
02-26-2003, 10:40 PM | #9 |
Project1970 - I have been told that the drop leafs will not fit on a 1970 C20 Custom Camper but I may be wrong. I dunno.
HotRod
02-27-2003, 10:58 AM | #10 |
Will the flip kit put the springs under the axle?
BADASS
http://www.dfwstangs.net/hosting/BAD.../badasssig.jpg 74' Camaro SBC/TH350 Thats all you need to know. Want some?...Come get some! |
02-27-2003, 11:19 AM | #11 |
Axel on top of the springs. With a flip kit Same thing you said but diffirent wording.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
