Old 12-11-2008, 05:41 PM   #1
Stock72c10
classic=of recognized value
Stock72c10's Avatar
Vacuum Lines on a Rochester Monojet
I switched out my carb and it seems to run decent, but I just want to know how to properly hook up the vacuum lines (I just hooked them up like the old one was hooked up and don't know if it was correct). In the pics below I have the EEC Canister hooked up to "C" and the Vacuum Advance from the Distributor hooked up to A & B (with a T connecting the two lines close to the carb). Does this sound right? Is it necessary to hook both A & B up to the Vacuum Advance, and if not which one should it be hooked to (I will plug the unused port of course). Thanks in advance
Stock72c10 is offline   Reply With Quote
Old 12-11-2008, 06:07 PM   #2
grancuda
grancuda's Avatar
Re: Vacuum Lines on a Rochester Monojet
mine is hooked to B and my air cleaner vacuum door is hooked to A
grancuda is offline   Reply With Quote
Old 12-11-2008, 06:11 PM   #3
Stock72c10
Stock72c10's Avatar
I have an aftermarket K&N 10" air filter on mine (no door) so I guess I can just plug C? Thanks for the quick reply.
Old 12-11-2008, 07:35 PM   #4
joekewl_chevyfreak
joekewl_chevyfreak's Avatar
mines simply clamped off
'68 chevy c10 1/2 ton inline 6, 250 2wd stock everything. exposed to elements for 40 years
'87 Dodge D150, 318 auto stock; D.D.
God meant for rubber to be burnt, not for an ear of corn
Myspace
joekewl_chevyfreak is offline   Reply With Quote
Old 12-12-2008, 12:23 AM   #5
OhNoJoe
OhNoJoe's Avatar
I got a few pics
OhNoJoe is offline   Reply With Quote
