Old 12-12-2008, 11:22 PM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
I need a blazer tank fill hose,...
Is this an auto parts item or can I get it from a board vendor?
I'm getting ready to install a new tank in my blazer and all the rubber hoses appear to be original. I need the big "fill" hose and all the smaller ones.
Any help would be great.
Keith
Convert to disc brakes.
Old 12-13-2008, 12:12 AM   #2
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: I need a blazer tank fill hose,...
Its a very odd size. You can go to a boat dealer or a hydraulic hose place to find it.... Usually, lol. I think it has a inner diameter of 1 1/8".
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 12-13-2008, 01:13 AM   #3
mdunn
LMC Truck has them in their catalog.
mdunn is offline   Reply With Quote
Old 12-13-2008, 03:34 AM   #4
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I got mine at a Fishing supply store.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 12-13-2008, 07:50 AM   #5
jamie72
jamie72's Avatar
napa has it.not cheap thou.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 12-13-2008, 09:44 AM   #6
70k52wd
Blaze-Air
70k52wd's Avatar
I had my local parts store just cut down a long high quality fuel hose. I had my old stuff for measuring... under 6 bucks, had it instantly.
70k52wd is offline   Reply With Quote
Old 12-13-2008, 10:02 AM   #7
lolife99
lolife99's Avatar
Thanks for all the replies.
Keith
Old 12-13-2008, 12:37 PM   #8
70 Suburban
Rods
mine was sold to me by the inch. I replaced both the one under the bed and in bed. about a $1 an inch
70 Suburban is offline   Reply With Quote
Old 12-13-2008, 12:56 PM   #9
Yukon Jack
Yukon Jack's Avatar
Here's a good pic of the fuel tank raplacement hose
from the tank replacement post in the FAQ
I have bought this hose from a local rubber hose supply house for about $12 a foot. My local auto parts stores couldn't get that size and the hose I got from one of the board vendors was actually the wrong inside diameter.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-13-2008, 01:03 PM   #10
leddzepp
Moderator
leddzepp's Avatar
It is a 1 3/8" diameter...hard to locate sometimes. Try West Marine, or any other boating supply store. It is NOT cheap. About $12-$15 a foot. www.truckandcarshop also sells it. I believe they have it by the foot, or in 6 foot sections as well.
Old 12-13-2008, 02:07 PM   #11
k5hart
k5hart's Avatar
I think I got mine from a heavy equipment supply store. It was a couple of years ago. I do remember it not being cheap.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 12-13-2008, 05:31 PM   #12
lolife99
lolife99's Avatar
OK guys,... NEW PROBLEM. I unboxed my new gas tank from ECE. The metal neck on the new (steel) replacement tanks come off the tank with a straight piece of 1-3/8" pipe. (angle slighly upward)
After looking at my original blazer tank (still installed) ,... it's different. It has a metal tank neck with several bends in it to "snake" around the rear body mount.
It appears that the ECE tank neck will run directly into the body mount.
Now what do I do?
It appears to be a blazer only problem. It doesn't matter when you put one of these tanks in a pickup.
Has anyone here run into this before?
Keith
Old 12-13-2008, 05:46 PM   #13
pound41
I am getting ready to do my tank. Since the hose is going to have a bend in it. it needs to have the metal in the hose to keep it from colasping. My local auto parts stores Napa etc. I live in Northern Va./DC. I tried dozens of the stores. Some had gas hose that would fit but not with metal. I got my hose off the web. It wasn't cheap.
pound41 is offline   Reply With Quote
Old 12-13-2008, 06:03 PM   #14
lolife99
lolife99's Avatar
Does anyone have a picture of a new replacement tank installed in a blazer? I need a shot of the hose and the left rear body mount.
Keith
Old 12-13-2008, 10:57 PM   #15
Thealien
Thealien's Avatar
Everything you need to know about the blazer gas tank install!!
Old 12-14-2008, 12:07 AM   #16
lolife99
lolife99's Avatar
Thealien,... Thanks for the info, I wish I would hve seen this before I spent $300.
Keith
Old 12-15-2008, 05:37 PM   #17
Big J
Big J's Avatar
You can always cut the neck off your stock tank and use a couple clamps with a piece of hose.
BAZINGA!
My Build
Old 12-15-2008, 09:28 PM   #18
k5hart
k5hart's Avatar
I wish I was more of a help. It's been a couple years since I put my tank in. I remember having the same problem but I was able to get the hose around the body mount. Will see if I have a pic.
Old 12-15-2008, 09:33 PM   #19
lolife99
lolife99's Avatar
k5hart,... pics would be great.
Also post some of your K5!
Keith
Old 12-15-2008, 10:33 PM   #20
Thealien
Thealien's Avatar
Its not a big deal, I did it to my tank. Make sure you or whoever solders on the neck uses a good solder paste to tin the tank. I know some have used hose but it is tight in there and I wanted it done right.
Old 12-16-2008, 08:36 AM   #21
k5hart
k5hart's Avatar
Here is the only pic I could find.
I know my hose is right on the body mount and I check it every now and then for cuts or rubbing through but nothing has happened yet. It took some work to get it in.
Old 12-16-2008, 10:52 AM   #22
Yukon Jack
Yukon Jack's Avatar
Like Big J said, cut off your old fuel neck and use it on the new one. I had mine cut off and soldered onto the new tank and what do you know - it was hitting the body mount. So I grabbed the hack saw and cut off the freshly soldered on old fuel neck and got some rubber hose to mate the old to the new.
Here are a couple pics to show how I used the old tank's filler neck. About a 4" piece of hose goes from the new tanks existing filler neck and attaches to the bent piece that I cut off my old tank, then it connects to the long piece that will go up the side of the Blazer.
I would rather have not had to use the extra rubber hose to splice this together but I have no worries that it will last a long time.
Old 12-16-2008, 12:56 PM   #23
lolife99
lolife99's Avatar
Thanks everyone for posting. Looks like I have work to do.
Keith
Old 12-16-2008, 11:22 PM   #24
jcfoote60
Active Member
jcfoote60's Avatar
I also invested in the wire re-enforced hose, not kinks, less fuel restiction, particularly with the after market tanks. the hose will not collapse or kink
jcfoote60 is offline   Reply With Quote
Old 12-18-2008, 10:13 PM   #25
theboxer
I know exactly what you are going through. I had a hard time finding the right diameter to fit the tank. There is a chevy parts pplace in Oklahoma City http://www.chevy-classic-parts.com/ they have exactly what you need.
theboxer is offline   Reply With Quote
