Old 12-14-2008, 03:02 PM   #126
sandking
.....I am working on it.....
sandking's Avatar
Re: Here is a "Not Your Typical" 4wd Blazer build
Thanks!! You are the same screen name on gd.com, right?
View my build thread HERE
sandking is offline   Reply With Quote
Old 12-18-2008, 01:35 AM   #127
DUNE GOON
The other thing you must be careful about on your front end setup is that, yes it does act as a sway bar, and yes it limits articulation. But the problem spot is the axle, it is possible that if you round a turn hard enough you will spin the tubes to the pumpkin. If you are running this setup I'd recommend putting a full seam weld around your tube to pumpkin. We thought of this when we were building my CJ8
Passanger side:
Driver's side:
DUNE GOON is offline   Reply With Quote
Old 12-18-2008, 09:21 AM   #128
sandking
sandking's Avatar
It will be fully welded around the tubes. It will also have a small truss that will help strengthen the axle. Thanks for the info.
Old 01-15-2009, 12:28 PM   #129
lgdpt
lgdpt's Avatar
Sandking - my neighbor....
This build is amazing. Let me know if you ever need a hand. I would be glad to help. I have to check your build out in person one of these days.
Im off Green River, by the way.
Travis
lgdpt is offline   Reply With Quote
Old 01-15-2009, 08:43 PM   #130
sandking
sandking's Avatar
Cool, your close, I am off Ontario and Lincoln. Feel free to let me know when you would like to check it out. Thanks for the props. Joey
Old 01-19-2009, 10:01 AM   #131
sandking
sandking's Avatar
Got a donor for the heart transplant, it's an LMG 5.3 from a 2007 Suburban. It should be at least 400hp by the time I am done with it.......
Old 01-19-2009, 07:41 PM   #132
trx450duner
trx450duner's Avatar
This thing is turning out sweat! What trans are you going to run?
trx450duner is offline   Reply With Quote
Old 01-19-2009, 08:35 PM   #133
sandking
sandking's Avatar
Thanks!! I have a TH350 and an NP205 T-case.
Old 01-22-2009, 01:33 AM   #134
trx450duner
will be a nice set up and awesome job on the cage and suspension work!
Old 01-22-2009, 01:11 PM   #135
sandking
sandking's Avatar
Thanks!! I am hoping to get more done soon.
Old 01-24-2009, 09:08 PM   #136
jdstx
jdstx's Avatar
I just read the entire thread and have a question. What type tubing are you using, EMT, IMC or RMC? Seriously, you have done a fine job on this build and I will definetly subscribe this one. One real question. Have you boxed or gusseted the frame at the cage/suspension tie in points?
jdstx is offline   Reply With Quote
Old 01-25-2009, 08:18 PM   #137
sandking
sandking's Avatar
PVC
I am using 1.75 x .120 wall DOM tubing. The frame will be plated in the areas that the cage attaches to. Then on the inside of the frame. it will have rectangle 2x4 tubing from top to bottom. That should do the trick.
Old 02-08-2009, 04:08 PM   #138
drbyrdman
drbyrdman's Avatar
blazer glass fenders
I know a guy making these!!
drbyrdman is offline   Reply With Quote
Old 02-08-2009, 04:14 PM   #139
vexvader
1967 C10 SWB
vexvader's Avatar
WOW! This thing is way over the top!!
I Love It!!!
Keep up the good work bro, you make us proud!!
I will follow along from here on out.
Vex
vexvader is offline   Reply With Quote
Old 02-08-2009, 04:44 PM   #140
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-08-2009, 06:15 PM   #141
glimmertwin01
glimmertwin01's Avatar
very cool
I wish i had access to rot free trucks to build... VT does this make you drool? I know it makes me get a lil Chubby
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 02-08-2009, 06:32 PM   #142
sandking
sandking's Avatar
I hope this guy knows how valuable these will be. Nice!
Old 02-08-2009, 06:32 PM   #143
sandking
sandking's Avatar
Thanks guys!!!!
Old 03-17-2009, 10:56 PM   #144
desertrat
desertrat's Avatar
Just checking in to see if there has been any updates.
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 03-18-2009, 12:17 AM   #145
LuckyHenriksen
LuckyHenriksen's Avatar
Wow sweet build. I have always wondered what a blazer would look like done up prerunner style. I am eventually going to do a similar build to me Bronco. That is a sexy cage!
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 03-19-2009, 08:24 PM   #146
sandking
sandking's Avatar
Sorry, no updates as of right now. Feel free to send money to the "Not Your Typical Blazer Build Foundation"..............
Thanks for the compliment.
Old 03-20-2009, 12:09 AM   #147
VA72C10
VA72C10
VA72C10's Avatar
Great work...will be watching...
Old 03-20-2009, 08:13 AM   #148
litebulblsc
litebulblsc's Avatar
More Info?
litebulblsc is offline   Reply With Quote
Old 03-20-2009, 08:24 AM   #149
drbyrdman
drbyrdman's Avatar
http://www.class3racing.com/showthread.php?t=1139
Old 03-25-2009, 12:05 AM   #150
jimbug
jimbug's Avatar
Great work looking forward to more juicy pics!
jimbug is offline   Reply With Quote
