Old 12-17-2008, 09:39 PM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Question Is there a trick to installing a bench seat cover?
I got a new seat cover & foam and although I'm not sure I'll keep it, if I do I want to install it correctly without any issues. It would seem pretty straightforward to me, but will it be easy or is there a trick to installing one so that it fits well?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 12-17-2008, 10:04 PM   #2
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Re: Is there a trick to installing a bench seat cover?
Brad, I installed mine back in the summer. I would recommend picking a very hot day and let the cover lay in the sun for an hour or so before installing it...but those days are few and far between, especially in Oregon at this time of the year. Your best bet is to turn the heat up in the room/garage that you plan on working in. Just make sure it is soft and pliable. Post some pics for us.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 12-17-2008, 10:14 PM   #3
lowriden58
lowriden58's Avatar
i also did mine back in the summer. was my first time and it turned out great
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 12-18-2008, 12:04 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Agree with the above. Summer is best or a warm garage. Spray silicone will also help to slide the covers on.
68gmsee is offline   Reply With Quote
Old 12-18-2008, 12:30 AM   #5
LEEVON
Moderator
LEEVON's Avatar
if you're not concerned with factory "correctness" try using black zip ties instead of hog rings (shouldn't see them anyhow). they're easier in my opinion. Don't forget to put new burlap between the foam and springs, otherwise it will cut and sag.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-18-2008, 12:56 AM   #6
chevy29267truck
i will have too do a seat next year also
chevy29267truck is offline   Reply With Quote
Old 12-18-2008, 02:32 AM   #7
Brad
Brad's Avatar
That's a great idea and I've got alot of those around.
I saved the burlap from the old seat, but it was only on the seatback. Should the seat portion have burlap also?
Old 12-18-2008, 02:41 AM   #8
BarryB
BarryB's Avatar
Yes especially the seat bottom, because that is the part, that takes the most wear. And do not use zip ties, I do upholstery work!! Hog rings are cheap and easy to install/remove. Burlap is cheap also, I just bought some tonite for a seat im doing, the expensive stuff was only 3.49 a yard. So replace both back and bottom.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-18-2008, 02:52 AM   #9
Brad
Brad's Avatar
I just found this over at Brothers:
http://www.brotherstrucks.com/techar...20INSTALLATION
Old 12-18-2008, 08:41 AM   #10
cdowns
cdowns's Avatar
i've always put the seatcovers in the dryer for 15min or so prior to installing and had a hair dryer handy during the install for streaching and wrinkle removal
Old 12-18-2008, 11:02 AM   #11
Wrenchbender Ret
I did mine a year or so ago. It came out good but I didn't realize it had a broken spring. It poked a hole in it.
Wrenchbender Ret is offline   Reply With Quote
