Old 12-19-2008, 11:44 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Stiff hinges?
When I open my hood I have to pull it up to open it, whereas when I first got it it sprung up. What do I do to fix it?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-19-2008, 11:53 AM   #2
nicolas72gmc
nicolas72gmc's Avatar
Re: Stiff hinges?
first thing I would say is try some lubricant? Dont mean to sound S.A. Mine was the same way and some moly grease did the trick. My .02
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 12-19-2008, 12:17 PM   #3
LuckyHenriksen
LuckyHenriksen's Avatar
Re: Stiff hinges?
Ya I would try lubin it
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-19-2008, 12:28 PM   #4
SactoJim
SactoJim's Avatar
Re: Stiff hinges?
WD40 works wonders!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 12-19-2008, 12:42 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Stiff hinges?
In addition to lubing the hinges, the latch ass'y also needs lubed. I was amazed to find that my latch was the reason that the hood would not pop up on my '96.
Member Nr. 2770
Old 12-19-2008, 03:07 PM   #6
cdowns
cdowns's Avatar
Re: Stiff hinges?
most 40year old moving parts could benefit from a good cleaning followed by lubrication
Old 12-19-2008, 03:10 PM   #7
thirdstreettito
Resident of Here
Re: Stiff hinges?
Thanks. I didnt know if lube would fix it or not. Now I know.
~Bradley~
Miss having a truck
Old 12-19-2008, 04:07 PM   #8
El Jay
Gone to greener pastures
Re: Stiff hinges?
WD-40 is your friend.
SOAK all of the pivot points & then "exercise" the hinges by moving your hood up & down a LOT.
Then spray some more.
You'll be amazed at the difference.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 12-19-2008, 04:49 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Stiff hinges?
I would use something other than WD 40 too, that stuff isn't all that great.
Study the hinges good, in reality, there will be like 6 or 8 points to spray IIRC.
If it is still stiff, and it doesn't seem to be actually sticking, then new springs are probably in order.
Old 12-19-2008, 04:58 PM   #10
El Jay
Re: Stiff hinges?
Andy,
We can agree to disagree about WD-40.
But you are right; there are a 1/2 dozen, or so, pivot points on the hood hinges, on both the "hood" side & the "fender" side and all need to be lubed & lubed well.
Old 12-19-2008, 05:09 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Re: Stiff hinges?
WD 40 works great for lubrication....liquid wrench works way better for freeing up rusted parts.
Old 12-20-2008, 12:22 AM   #12
thirdstreettito
Resident of Here
Re: Stiff hinges?
Thanks guys, this really helped. Now, where did I put that Weasel Piss...
~Bradley~
Miss having a truck
Old 12-20-2008, 12:42 AM   #13
'68 C-20
'68 C-20's Avatar
Re: Stiff hinges?
I use air tool oil, the stuff with Moly in it. The Moly stays behind for a long time. The oil comes in 1 or 2 oz containers and has a nice drip oiler tip on it for precise application.
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 12-20-2008, 12:54 AM   #14
thirdstreettito
Resident of Here
Re: Stiff hinges?
Can I get it at Advanced/Napa/AutoZone?
~Bradley~
Miss having a truck
Old 12-20-2008, 12:58 AM   #15
Shane
Shane's Avatar
Re: Stiff hinges?
sprayable white lithium grease ...
Shane is offline   Reply With Quote
Old 12-20-2008, 09:54 AM   #16
LONGHAIR
Re: Stiff hinges?
WD-40 seems to be everyone's generic spray "Lube".....like it is some miracle stuff that can do it all. The problem with things that "do it all" is that they don't do most of them very well. WD-40 is probable best for spraying inside a wet distributor cap....it is after-all specifically designed for "water displacement" (the WD).
For a penetrating oil or other general lubrication, there are far better choices.
I'm with Shane on this one, White Lithium grease is the thing here. It should also be used on the other moving parts of the body.....door hinges, hood and door latches, tailgate hinges/latches, etc.
LONGHAIR is offline   Reply With Quote
Old 12-20-2008, 10:04 AM   #17
cdowns
cdowns's Avatar
Re: Stiff hinges?
i use lots of wd40 but mostly for just loosening up and clearing out the old crap and accumulation then follow up with the lubrication from the sprayable white lithium// just lubricating is ok but cleaning up then lubricating is far superior
Old 12-20-2008, 10:14 AM   #18
LONGHAIR
Re: Stiff hinges?
Cleaning, especially rusty flakes/grit, is always a good thing.
