12-20-2008, 05:57 PM | #1 |
Has anyone ever made a Homemade Flip Kit?
First off Merry Christmas. My question is has anyone ever made a flip kit for a 67-72 with rear leaf springs? If so what all is involved?
12-20-2008, 09:54 PM | #2 |
Re: Has anyone ever made a Homemade Flip Kit?
The best and cheapest way is to cut off the old perches and weld new ones on. Then all you need to buy are new perches.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
12-21-2008, 05:46 PM | #3 |
Agreed!!!
12-21-2008, 09:37 PM | #4 |
Truck Nut
Won't that put the rear end to far back??? On my bell tech flip kit, it has a hole in the flip saddle that has to be towards the front of the truck. Just wondering???
Tony Kee Texas Square Bodies |
12-21-2008, 11:36 PM | #5 |
The offset hole is to correct pinion angle. Set ur PA and weld on.
12-22-2008, 12:13 AM | #6 |
my under standing is the off-set hole is to move the diff back. when you flip the axle to the top of the springs it moves it closer to the transmission, so to keep the slip joint from bottoming out during suspension travel, the diff is moved back 3/4" IIRC
to correct pinion angle, the u is uneven, or with the better kits, it is adjustable
CHEVY ONLY Last edited by joe231; 12-22-2008 at 01:33 AM. |
12-22-2008, 12:40 AM | #7 |
i just did that to the 58 apache we are doing, they are right, center you axle side to sid, set your pinion angle and weld the perches on, easy.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
12-22-2008, 03:40 AM | #8 |
I made a set for my blazer as well as zero rate to relocate the axle. Not difficult if you have access to the proper tools. They are not that expensive to buy either.
Mike Redpath Last edited by Musclerodz; 12-22-2008 at 03:42 AM. |
12-22-2008, 09:17 AM | #9 | |
12-22-2008, 09:45 AM | #10 |
Watch out for your cornhole !
Remember that axle saddles are available at any trailer store, Northern Tool, or Tractor Supply MUCH cheaper than mail order specialty places too.
12-22-2008, 11:19 AM | #11 |
Thanks guys.
12-23-2008, 10:14 PM | #12 | |
can you elaborate on the "zero-rate" what is it, what does it do, and how did you make it?
CHEVY ONLY |
