Old 12-21-2008, 08:05 PM   #1
HuggerCST
HuggerCST's Avatar
70 vs. 71 brake booster difference?
I see that they have different part numbers. Does anyone know the difference? I'm switching my '70 power drum/drum to 71 style disc/drum. Can I simply change the master cylinder & prop valve, or do I need to change to the '71 style booster too?
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 12-21-2008, 08:54 PM   #2
cparman
sharp as a marble
Re: 70 vs. 71 brake booster difference?
I think Chevy used two different suppliers back in the day. If you can look it up on NAPA's site and see a picture you will see the difference in the two styles of booster. They also use a different master cylinder for each. Hope this helps
cparman is offline   Reply With Quote
Old 12-21-2008, 10:12 PM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Wynne,
Brake Booster from your 70' will work if your gonna change to the 71'-72' disks.
I have a 69' and I'm using the brake booster from it for the 71'-72' disk conversion (just did this conversion last weekend). I of course needed to change master cylinders and now use the proportional valve. Drum brakes use a smaller resiviour (sp) master cylinder and a distribution block. Note: brake line sizes are different also
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-22-2008, 12:17 AM   #4
HuggerCST
HuggerCST's Avatar
Thanks!
Wynne
Build thread
53 Chevy shortbed
69 Camaro
