Old 12-22-2008, 12:12 AM   #1
mycool72
mycool72's Avatar
Another alignment question
What are you guys with bags using for alignment on the uppers ? Are you just running a shi load of shims or some sort of larger spacer? Pics would help...thanks....
mycool72 is offline   Reply With Quote
Old 12-22-2008, 05:34 PM   #2
mycool72
mycool72's Avatar
Re: Another alignment question
echo
Old 12-22-2008, 11:54 PM   #3
tonythezeek
tonythezeek's Avatar
OMG! you read my mind! (that's why i love this forum) I noticed a butt load of shims when pulling my upper control arms. Luckly, I kept em and and used them for the new control arms I pilfered. As I was putting things together, that thought crossed my mind. Very curious (like George, the Monkey) on this one
tonythezeek is offline   Reply With Quote
Old 12-23-2008, 01:47 AM   #4
TylerHuff
TylerHuff's Avatar
Originally Posted by mycool72 View Post
What are you guys with bags using for alignment on the uppers ? Are you just running a shi load of shims...
yep a hole bunch o' dem
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 12-23-2008, 04:51 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
ttt
Old 12-23-2008, 10:06 AM   #6
mycool72
mycool72's Avatar
Surely there is some sorta sleeve that you can put over the bolts that will act like a spacer....hmm....but i wonder if it would be strong enough?! Time to go to the home depot hardware section....
Old 12-23-2008, 11:06 AM   #7
Tony@AirRideTech
Junior Member
You can use a sleeve or steel bushing if you want... all you are doing is shimming the arms in to gain alignment. One of the reasons they engineered that front end with that many shims is because that is back in the days when automakers were engineering their vehicles to last for more then 4-6 yrs (average payment terms and extended warranties) and they were allowing you to be able to compensate for crossmember sag. They also did it because body / chassis tolerances in those days were measured with a ruler
Tony@AirRideTech is offline   Reply With Quote
Old 12-26-2008, 02:22 AM   #8
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
I used 1" longer A-arms and camber never gets too outta whack throughout the travel. I use no shims.
Imperial Kustom is offline   Reply With Quote
