Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 12-24-2008, 01:48 AM   #1
dan42
dan42's Avatar
Hood spring replacement -
Who has done this on their '67-'72? Is it hard? I just bought new hinges, and I was gonna use the old springs, but I haven't taken the hood off yet, so I was wondering if I am gonna have to muscle the springs on or do they come off relatively easily. Let me know your experience with this if you would.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline
Old 12-24-2008, 02:56 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Hood spring replacement -
I haven't done this myself but I read about a trick where you get the spring to expand (either open or partly closed, depending on vehicle, I think the trucks are partly closed). When you do this you will see gaps between the coils. You then place scrap metal into this gap area and then open the hood. This will keep the spring from being able to compress and then there is enough slack to just unhook the spring.
I have also heard of a trick to paint hood springs and get all of it painted. Run a chain from the hook to the leg of an engine hoist and the other end to the hook of the hoist. Then pump the jack up like you are lifting an engine, which in this case you are expanding the spring enough to paint into the area that would normally be closed together.
Hope that helps some.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 12-24-2008, 06:45 AM   #3
JimKshortstep4x4
Attached is a picture of a removal installation method that I have not tried but it looks like it would work. A chain with a flat hook is made up and to remove the spring, you hook onto the spring and pull on the chain. Apparently it does not take that much force to pull the spring off of the hinge. Of course the hood has to be held up by some means unless you have the hinge off and clamped up in a vise.
I have always used a very large screw driver with the hinge off but it is not a very safe method so I am going to try the chain procedure next time.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
JimKshortstep4x4 is offline
Old 12-24-2008, 11:42 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
Originally Posted by ChevLoRay View Post
I saw a picture once where someone had used nice, shiny open-end wrenches in the gaps of an open hood spring to allow them to remove the spring. But, like cdowns says, you gotta outthink the spring to be able to "deal" with it....
Let us know what your thinking is...
Do this, then get a piece of rope and loop it on the spring and pull the rest of the way. Might want to think about new springs since your going through all the trouble. When I put new springs in my new hinges, I used a floor jack to stretch the spring and used the wrenchs to keep the spring open.
Beat it to fit,
Paint it to match...
Sinister is offline
Old 12-24-2008, 11:47 AM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I just used a screw driver with the hinge in the open position.......It's not that hard. I ended up pitting them back on for powder coat, because the springs were together and with them on they were slightly opened between the coils.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline
Old 01-29-2009, 10:33 PM   #6
joemacho
joemacho's Avatar
i used a big pry bar or a long flat screwdriver to take them off then i used a brake spring removal tool the long one and put the spring on its hard but works.
joemacho is offline
Old 01-30-2009, 12:46 AM   #7
72lb4x4
One of my factory manuals for something Chevy shows a T shaped too with a hook at the bottom of the T. The tool is made from 1/4 or 5/16 rod.
Hook it on the spring and pull.
72lb4x4 is offline
Closed Thread
