Old 12-24-2008, 12:48 PM   #1
502tripower
502tripower's Avatar
Shift Indicater Help
I have a 2002 2500HD with the Alison trany. Yesterday I noticed the shift indicator is working sporadically. It will light up on R, 3, 1 and, sometimes on P. The trany seems to be working properly in all gears but I have to count the clicks to make sure I am in the right gear. Also because it only works some times in P the locks don't unlock when you put it in Park. Last night I was parked with the engine running and the Park indicator was working then all of a sudden it went out. We have had a lot of snow the past few weeks and I was wondering if there was a electrical connection on the trany that may have been disturbed? Any help would be appreciated.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 12-25-2008, 03:40 PM   #2
502tripower
Re: Shift Indicater Help
Well now the trany will not shift into OD and makes a clunk when putting it into gear.
98' FXD
2002 2500HD
Old 12-28-2008, 08:49 AM   #3
truckdude239
truckdude239's Avatar
sounds lieka loose wire some where or sensor gone bad
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-03-2009, 05:46 PM   #4
shade67
the transducer on the side of the trans where the shift lever hooks to the trans is bad. I had ignored mine and it would occasionally not start- apparently thinking I was tring to start in gear!
Scott
66 chevy short step 327 4speed
67 chevy Short Fleet tpi 350 700r4
72 chevy K10 swb
01 GMC Sierra
01 Pontiac Bonneville
shade67 is offline   Reply With Quote
Old 01-06-2009, 06:00 AM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
The shift indicator or as it's commonly called up here the "PRNDL SWITCH" is causing you troubles. Mounted to the side of the tranny.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-07-2009, 12:33 AM   #6
502tripower
I replaced the prndl switch and all is good. Boy GM is mighty proud of that part....226.00 for a plastic switch....I think instead of getting better these trucks are going backwards. All this computer electronic carp sucks....
98' FXD
2002 2500HD
