DDOV
im getting new exhaust and i was wondering what you think about what im wanting to get... i have a street/strip motor and i want it to be quiet on the road..(sleeper) so i have exhaust cutouts for the strip.. I want 2.5 in. from the headers into a single 3, or 4 in. pipe all the way back to a newer truck muffler... i think its off a 2500hd or f250.. and a turndown right after.. what do you think?
If you don't like the way I drive, stay off the sidewalk http://67-72chevytrucks.com/vboard/s...d.php?t=317070 The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
Re: New exhaust
3.5 inch single gets you the same cross sectional area as the two 2.5 inch diameter pipes.
Re: New exhaust
why the bigg truck mufler? Sounds cool just wondering. I like the flowmaster 10 series myself.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!! 70 Chevy C-10, 355, th400, 3.73's 2/4 drop |
Re: New exhaust
Honestly, I would just get a pair turbo mufflers and run a true dual setup. These are very tame at cruise but are semi-loud at full throttle. If you add an H pipe, this will further quiet and mellow the tone. Furthermore, turbo mufflers flow extremely well. You wouldn't be losing much if any power by running them on the street.
1977 GMC Sierra Grande |
Re: New exhaust
True duals and an h pipe would be my choice also. With the right mufflers its not loud at all. I had proflow muffler done on a 383 street truck and it was real tame. What size is the motor?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
DDOV
Re: New exhaust
355, i just want it to be really quiet... i love loud things, but i just want no one to think anything of it.. i want people to think its just an old beater...
mini truck racer
Re: New exhaust
I just went through this on my C-10 . I did the trailing arm crossmember mod and ran 2.5" to a pair of Pypes street pros and they are load . They are so load i told the muffler shop to just put dumps on it vs tail pipes for now cause there coming off . I am also looking for a quiet free flowing muffler for my street truck . The Luv has scofeilds on it and it is load , but has a purpose .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#8 | |
Re: New exhaust
#9 | |
Registered Truck Offender
Re: New exhaust
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#10 | ||
mini truck racer
Re: New exhaust
Marv , I was gonna put these on my Camaro , but stuck'em on the truck instead . I bought them used so maybe there blown out ? Compression is 10.2 to 1 so it is movin some air ; if you know what i mean . I can tell you when i fired it up yesterday my wife came out fussin about it sayin " I thught you were just gonna have a normal truck with this one , sounds like a race truck to me !" I'll try and get a sound bit and post on here . I was looking for something mellower guess im getting old .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 12-27-2008 at 02:40 PM. |
Re: New exhaust
When I had my 01 SS Camaro I was looking for a very mellow tone at idle with a very mellow tone at WOT with the cut outs closed. What I ended up doing was:
Long tube headers Dual electric cut outs right off the collector 3" to 2.5" reducers on the non cut out side Dual Catco cheap cat's 2.5" dual to single 3" flowmaster y collector Single 3" in Hooker Aerochamber muffler with the factory dual 2.5" tips out. (forgot how good it sounded until I found the sound clip: http://73-ls1.com/misc/Thunder236.wav ) Thing sounded close to stock as far as tone and how loud it was. You would have to listen to hear the big 236/230 .595/.575 lift cam in it. Then, on race day, open the cut outs and it was one loud car. My truck is pretty deafening right now with 3.5" collectors down to 3" 3" X-pipe Warlock mufflers with Dual electric cut outs hung on the muffler No dumps It was louder with the plugs they give you for the muffler as they have an angle to them, but with the flat portion of the cut out, it deadens the sound some. I'm planing on getting rid of this set up and going with: 3.5" to 3" reducers Dual electric cut outs 3" to 2.5" reducers Dual 2.5" in / Single 3" out Hooker Aero Chamber Muffler Dump just before the rear tire on the passanger side. If this isn't quiet enough, I'll put something between the out put of the muffler and the dump. I don't need the noise or the performance when capped. It will move plenty for around town even with a big plug in it.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 12-27-2008 at 04:54 PM. |
Re: New exhaust
I added an X pipe and it made tons of difference. I agree with the turbo muffler idea, and you could always add some glass packs in font or after those to quiet it even more. And I read an article talking about pipe size, if you start out with 3 inch off the collectors and neck it down to 2.5 inch before the mufflers, you can pull more torque and still keep it relatively quiet
Re: New exhaust
I have several dynos on my set up and other buddies that show no loss of TQ running dual electric cut outs right off the headers. Actually it only gained in all 3 cases. In my case one was with the stock cam and the other was with the bigger cam. Both were in my 01 SS. Even the back to back with my truck the open headers lost nothing bellow and only gained.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Re: New exhaust
Here is my 01 SS after the cam. This is the TQ difference:
![]() Not sure If I can find the ones on the truck..
#15 |
mini truck racer
Re: New exhaust
Wow , 24 hp @ 5000 !
#16 |
Re: New exhaust
Headers with an x pipe and hollowed out turbo packs sounds wicked.If you dont want the loudness of straight pipes try Thrush glasspacks,it sounded great with these also but you couldnt hear it in the cab much at all.
Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
#17 |
Re: New exhaust
I just took the thrush flowmaster look-a-like off my truck cause they were too loud. I put dynomax ultra flows 3". They are tons quieter and flow more than the others.
#18 |
DDOV
Re: New exhaust
i ended up just putting stock replacement mufflers on it, with the cutouts.. its awesome.. all you can hear is the fan pretty much.. i love it.
here it them being uncapped. it sounds a little loud at first.. but thats because i took two of the 3 wingnuts off before i recorded so the vid wouldnt be as long, but it compromised the sound a little.. just note that at first its a lot quieter
