Old 12-27-2008, 03:48 AM   #1
mark 68
Question 250 with a turbo 350
What would be the best way to swap a 3 speed transmission (on the column) for a turbo 350. I have an idea on most of the problems like drive shaft and transmission cross member. But the one thing that i am stuck on is how to do the kick down cable, since my single barrel has no place for a kick down cable? Oh yah this isn't for my truck but my 64 nova.
mark 68 is offline   Reply With Quote
Old 12-27-2008, 12:28 PM   #2
caja_larga
Re: 250 with a turbo 350
I running without the cable hooked up and it seems to be ok(we are not talking break neck speeds in a 250) There are kick down bracket out there for the 250. I had one and cut it up to make thottle linkage for my hot rod.
caja_larga is offline   Reply With Quote
Old 12-27-2008, 01:34 PM   #3
Livrat
Member #1049
Livrat's Avatar
There was a factory t350 put in some vehicles, I found a t350 complete kickdown setup in a 74 nova,.. I also have seen them in Chevelles and later 70's trucks.
The only issue that I know if is your Nova has a throttle rod instead of a cable which was used in 68 and new cars and 71 and newer trucks.. both used different bell cranks bolted to the intake manifold..
Livrat is offline   Reply With Quote
Old 12-27-2008, 02:53 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
This is a 71-2 truck with cables, not rods.
Sometimes the Craftsman "choke enhanser" is the only way I can get those 1bbl carbs to run!
PICKMUP is offline   Reply With Quote
Old 12-28-2008, 01:09 AM   #5
mark 68
Thats what I needed to know.
thank you
Old 12-29-2008, 01:30 AM   #6
mark 68
Something I have to say is I get better information and from nicer people here then any other sites.....
Thanks.
