Old 01-08-2003, 08:40 PM   #1
Rastus
Biggest Tires with stock suspension?
I was wondering if any of you guys have any in-sight as to how big of a tire I could go on a stock Silverado....the Control Arms are up as far as they will go in the front. I will cut a bit of the front bumper skirt if need be.
93' 1500 Silverado Ext. cab Fullsize bed.
Dual exhaust with Chrome tips, Exiting at the rear.
Rastus is offline   Reply With Quote
Old 01-08-2003, 08:52 PM   #2
Rastus
Also:
I am hoping I can put ATLEAST 31's on it.
Old 01-08-2003, 11:12 PM   #3
My 96 has had 31x10.50-15 on 8" SS wheels and no clearance problems. (front or rear). I think I have see another guy near my work and he has 32x11.50 on his 2wd and it looks like they clear OK also.
Palf70Step is online now   Reply With Quote
Old 01-08-2003, 11:57 PM   #4
Rastus
Alright, thanks
Time for some Baja Claws
Old 01-08-2003, 11:59 PM   #5
Rastus
Alright, thanks
While i'm with the tires...would you guys recommend getting Powertrax, or Lockright lockers that don't sound harsh like the rest?
Old 01-10-2003, 06:44 PM   #6
Rastus
Do you have a pic of your truck?
Old 01-10-2003, 08:29 PM   #7
Don't have a picture with the 31's on it, but this is with 275/60. the 31's are about an inch taller and slightly narrower. I went to street tires to be a bit quieter and since I wasn't going to do any serious hauling with this one.
Old 01-10-2003, 08:37 PM   #8
Rastus
Do you think I could fit 33's, or would that be on the ragged edge?
Old 01-13-2003, 10:27 PM   #9
Rastus
?? Any ideas?
Old 01-13-2003, 11:48 PM   #10
Dunno. I think you'd be pushing it a might.
Old 01-14-2003, 01:01 AM   #11
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
id have to check but im preeeeetty sure on that year chevy , you can fit 33s, but they rub when flexed, im not quite sure, i know for less than 150 a cheap 2 inch body lift would fit 33s anyone agree? oh , is it a 2wd or a 4wd?
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 01-14-2003, 05:21 PM   #12
Rastus
It's 4WD.
thanks
Old 01-30-2003, 02:17 PM   #13
nuideas
33 x12's
I have put 33 x12 on the rear of mine for snow and mud and they are OK until you hit a dip or hole. They WILL RUB on occasion! I think putting them on the front would be risky at best. I'd stick with 31's if the'll do. nuideas
nuideas is offline   Reply With Quote
Old 02-01-2003, 02:42 AM   #14
chevypete396
chevypete396's Avatar
on a 4X4 33-12's should fit all around... Pete
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205
Building the motor, painting the engine bay, rewireing everything...
(775)-527-1199 / ryanspeterson@msn.com
chevypete396 is offline   Reply With Quote
Old 02-01-2003, 02:47 AM   #15
chevypete396
oh, sorry I am thinking 67-72 years... on a 93 4X4 I think 32 is as good as it gets and they will rub a little but not to bad- I cant remember the the 3 letter equivalant (295 or 305? or something like that)... Pete
Old 02-02-2003, 12:10 AM   #16
Rastus
Thanks fellas, I think I'm going to go with Lockers and some 31 inch tires.
Thanks.
Old 02-18-2003, 09:25 PM   #17
Rob Dundrea
Big Block Power
Rob Dundrea's Avatar
You can put a 305/70 under it but will need 8" wide wheels, with 5" of back spacing, they are close but they fit on the 1/2 tons, same combo on my dads 98 Tahoe, and on the 3/4 tons just crank torsion bars up 4 turns and the will fit that too!!
Rob Dundrea is offline   Reply With Quote
Old 02-24-2003, 10:04 PM   #18
phantom dually
Project92 SWB stepside
phantom dually's Avatar
33's will go on a 4x4. I have a 94 3/4 ton 2wd and they fit on with 33x12.50 on a 15x10 wheel. I did trim the front air dam and later added a 3" body lft to keep from rubbing on bumps!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-28-2003, 07:28 AM   #19
68_Step
Palf70step: Is your 70 step lifted in the rear? I have a 68 step and it sits much lower, rear is about same height as front.
Thanks!
68_Step is offline   Reply With Quote
Old 02-28-2003, 07:49 PM   #20
68_Step No mine is all original suspension. Although mine was ordered with HD suspension/springs (owner hauled cattle)
