Old 12-29-2008, 09:09 PM   #1
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
3 speed manual drive shaft
how many splines are in the slip yoke?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 12-29-2008, 11:15 PM   #2
big_al_71
big_al_71's Avatar
Re: 3 speed manual drive shaft
I have the one I took off my truck in my shop will be glad to count them for you tomorrow..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-29-2008, 11:27 PM   #3
vasquezmrysvll
"the other guy"
thanks alot
Old 12-29-2008, 11:32 PM   #4
Cyclone
Cyclone's Avatar
Early non-syncro 3sp were 16 spline. All late and full-syncro 3sp were normal 27 spline.
Cyclone is offline   Reply With Quote
Old 12-30-2008, 01:21 AM   #5
vasquezmrysvll
"the other guy"
thanks, im looking for a yoke for my powerglide which has 16 splines. off to the wreckers i go
Old 12-30-2008, 01:25 AM   #6
Cyclone
Cyclone's Avatar
Glide should be 27 spline
A great referance article here re: trans/splines etc.etc.
Old 12-30-2008, 01:44 AM   #7
vasquezmrysvll
"the other guy"
mine has 16?
Old 12-30-2008, 01:46 AM   #8
Cyclone
Cyclone's Avatar
Early cast iron PowerGlide?
Old 12-30-2008, 01:53 AM   #9
vasquezmrysvll
"the other guy"
aluminum
Old 12-30-2008, 01:56 AM   #10
vasquezmrysvll
"the other guy"
it was pulled from a 4 door 64 impala along with a 250
http://www.dennysdriveshaft.com/p305...16_spline.html
90 bucks for a slip yoke? kinda steep?
Old 12-30-2008, 11:55 AM   #11
Cyclone
Cyclone's Avatar
A shop here has good used ones for $50. Can pick one and ship if you like.
Old 12-30-2008, 01:23 PM   #12
vasquezmrysvll
"the other guy"
let me check the local bone yard, then i may take you up on that offer. thanks
Old 12-30-2008, 01:59 PM   #13
Cyclone
Cyclone's Avatar
$73. for a new one @ Drive line in West Sac
Old 12-30-2008, 03:12 PM   #14
kcjones
I wish I was a cowboy
kcjones's Avatar
Cyclone, which shop? I'm looking into a 700R4/4L60 swap with my TH400 in the future (maybe a year or more, though), and I want a good resource for tailshafts/housings/mounts. Driveline Service in SR is awesome for driveshaft work.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 12-30-2008, 03:21 PM   #15
Cyclone
Cyclone's Avatar
Thats the one, been using them for years.
Old 12-31-2008, 12:20 AM   #16
Jeffvega
Is a th350 auto the same spline?
1970 GMC LWB ALL STOCK FOR NOW
Jeffvega is offline   Reply With Quote
Old 12-31-2008, 12:27 AM   #17
vasquezmrysvll
"the other guy"
th350 and 700r4/4l60 all share the same 27 spline yoke. IIRC the lengths may be different.
Old 12-31-2008, 03:05 PM   #18
kcjones
kcjones's Avatar
I'm pretty sure that isn't correct. Th350 and 200R4 share the 27 spline yoke, but the TH400, 700R4, and 4L60 all have a 32 spline yoke. 700R4 and 4L60 are identical in yoke, length, and mounting pad. TH350 and TH400 are different in length and yoke.
Basically, you can swap a TH350/200R4, I think you just have to move the mounting location, but the yoke and driveshaft can remain.
You can swap a TH400 for a 700R4 or 4L60, keep the yoke, but move the mount and shorten the driveshaft.
I've never heard of a 16 spline 'Glide, but obviously they exist. Why a 'Glide in a truck?
-Kris
Old 12-31-2008, 03:15 PM   #19
vasquezmrysvll
"the other guy"
700r4 and 4l60 both use 27 spline, i have one of each in front of me. th400,super t-10, and i belive 4l80e all use 32 spline
Old 12-31-2008, 03:19 PM   #20
vasquezmrysvll
"the other guy"
oh, as for the glide in the truck... im tired of pushing my project around the yard and shop. my pops parted out a 4 door 64 impala and it had a GOOD running 250 with the glide. i couldn't beat the price
Old 01-01-2009, 04:16 AM   #21
Jeffvega
what does the stock 3speed manual have?
Old 01-01-2009, 12:04 PM   #22
vasquezmrysvll
"the other guy"
as for the 3 speed manual slip yoke, i will like to know as well?
Old 01-01-2009, 01:58 PM   #23
Cyclone
Cyclone's Avatar
From earlier
Old 01-01-2009, 02:24 PM   #24
vasquezmrysvll
"the other guy"
how do you tell the diff between syncro and non?
Old 01-01-2009, 02:41 PM   #25
Cyclone
Cyclone's Avatar
Open this, 341 is an early non-syncro. 343 & 351 are the full syncro versions(27 spline)
