Old 12-31-2008, 09:50 PM   #1
nac593
brake bleed question
I just switched the rear to discs. Can I just bleed the back ones, or do I have to do the front ones also?
nac593 is offline   Reply With Quote
Old 12-31-2008, 11:37 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: brake bleed question
Did you swap MC's also.I ask because your brake system needs to be "balanced".The rear disc may require more or less fluid to operate properly.You may also need a new proportioning valve.If you have the right MC and did not loosen or remove any of the front brake lines you may get by without bleeding the fronts.But since you're already there.....
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-01-2009, 09:12 AM   #3
cdowns
cdowns's Avatar
yes you need a disc/disc master and proportioning valve i think new size for brake lines for proper operation of 4whell discs
