Old 01-03-2009, 09:20 PM   #1
kevinr1970
Heater problem.
I have been having problems with my truck lately ('06 GMC regular cab) with heat control.
If I have the heat switch pushed all the way up (hot) then bring it down to about the 2/3 mark (still in the "red" area) it will start blowing cold air after a few minutes.
If I move it up a notch, after a minute or two it will start blowing hot air again. Not warm, but hot like it is pushed all the way up.
If I bring it back down a notch it starts blowing cold again. Not cooler, but cold.
It seems I only have hot or cold and no in between??
This is something new as far as I can tell; I am pretty sure I could regulate the temperature the past two winters.
I have checked the coolant overflow and it appears to be full. Even added about a 1/4 a bottle of antifreeze just to be safe but that brought the overflow up over the full mark.
Anyone else having problems like this?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-05-2009, 08:05 AM   #2
truckdude239
truckdude239's Avatar
Re: Heater problem.
sounds like the switches have gone bad
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
