Old 01-05-2009, 06:30 PM   #1
Slik69
Best plug for tired engine
I am wondering what's the best plug to run in my tired dog. I am building new motor, but I need this thing running better in the meantime. It's running ok, but seems to be using very very much gas. I mean a lot considering how far I have driven it. It's an old 327. Does anyone know where thes liked to be timed. I have a quadrajet carb and HEI. I just think I have plug issues that could be contributing to this. I don't know if they should be hot or cold plug. I am getting mixed information.
Tired motor, little blow-by, no white smoke from tailpipes, runs good. Idles poor. Have to drop her in drive at stop light sometimes not because it will shut off, but because you know it shoudl be idling better. A friend of mine thinks the motor is good, but I suspect it's tired.
Slik69 is offline   Reply With Quote
Old 01-05-2009, 07:34 PM   #2
heavy71chevy
heavy71chevy's Avatar
Re: Best plug for tired engine
what size is the carb? sounds like it might be running abit rich or needs a tune up
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 01-05-2009, 08:06 PM   #3
lowriden58
lowriden58's Avatar
how old are the plugs/wires/cap/rotor?? whats the timing set at? fuel filter been changed recently?
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-05-2009, 08:16 PM   #4
Slik69
quadrajet carb, new cap wires plugs, vac advance module. Dist was used.
Old 01-05-2009, 08:30 PM   #5
lowriden58
lowriden58's Avatar
Old 01-05-2009, 09:04 PM   #6
Slik69
I believe between 6-8 initial. The carb shop set it for me.
Old 01-05-2009, 10:24 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
So, how many miles on the clock? My 350 is the original block and the odometer shows 11K. It could be 111, or 211K for all I know. The heads are later. My engine has some blow-by. Is mine tired? It's got some issues, I'm sure. Like I said, blow-by, leaks oil from rear main. I would like a crate engine. I have several people who want my engine. Maybe I should re-think, huh?
I'd run a compression test, to let you know "stuff".
As for plugs, my engine is running AC RapidFire. It used to gas-foul plugs when I had an Edelbrock 1405 on it, with an adapter to fit the carb to a Q-Jet manifold. I now have an Edelbrock 1901 on an Edelbrock Performer intake. The mixture is a lot leaner with the new carb/manifold. The old HEI that was from a junkyard died, and I replace it with an ACCEL HEI, that is a reman unit with their name.
My thinking is that you get the fire right, and the carb right, and it will be a good engine. If it ain't knocking, and the compression is good, you should be good-to-go.
Member Nr. 2770
Old 01-05-2009, 11:10 PM   #8
Slik69
Yeah I think a compression check is in line next. It's weird because the trucks runs good, idles good in park, it's just when I'm sitting at the light. I just had a guy tellme yesterday there was nothing wring with it. He was just listening to it run after working on some other things. I have another mechanig tell me it's tired. No way to really know than doing compression test.
