Old 01-07-2009, 07:41 PM   #1
Knothead
Knothead's Avatar
Clutch Pedal & Fork
Does anybody know where I can locate the correct pedal for a '56? The splines on the one I have doesn't mesh with the cross shaft at the correct angle. Also which release fork will work with the original setup? I found one on evil bay for $70.00!!! , lists a bunch of different applications for it, Want to make sure it will work.
Knothead is offline   Reply With Quote
Old 01-08-2009, 12:08 AM   #2
Caveman49
Re: Clutch Pedal & Fork
Are you just needing the pedal arm, or what? I have a 56 parts truck.
Caveman49 is offline   Reply With Quote
Old 01-08-2009, 02:10 PM   #3
Knothead
Knothead's Avatar
I just need the actual pedal your foot comes in contact with.Also the release fork that clips in bellhousing.
Old 01-09-2009, 08:23 PM   #4
Caveman49
I'll check the 56 I have in the back, see what's there. I'll get back with you tomorrow.
Old 01-10-2009, 04:45 PM   #5
OrrieG
OrrieG's Avatar
I still have the stock clutch linkage setup for my 59 and will not be using it. Didn't know it was worth $70, LOL. If Caveman can't help you pm me.
Old 01-10-2009, 06:07 PM   #6
Knothead
Knothead's Avatar
Thanks Guys ,I'll check back later.
Old 01-11-2009, 09:32 AM   #7
Caveman49
Sorry I didn't get back at you yesterday, rained like crazy here.....all that's left on my 56 is the brake pedal. I do have the clutch assembly pedal from my 59 I won't be using, it should be the same. Don't have a release bearing fork.
Let me know if you're interested, I can take a couple pics and send you.
Lee
Old 01-13-2009, 12:33 PM   #8
Knothead
Knothead's Avatar
Not sure if they are interchangable, That's the issue I have now. The pedal & cross shaft don't mesh correctly. Everything looked good until I tried to assemble.
Old 01-13-2009, 12:50 PM   #9
OrrieG
OrrieG's Avatar
I am really busy until Thursday but will dig out my stuff and take some photos so you can compare to yours to what I have to see if it will work.
Old 01-24-2009, 12:46 AM   #10
Knothead
Knothead's Avatar
Can someone post the part number for the correct fork. I got a nice pedal, worked great. The clutch fork I bought isn't the right part.Also where can I get a brake pedal?
Old 01-24-2009, 02:28 PM   #11
OrrieG
OrrieG's Avatar
I looked this morning and all I could find clutch related was the lever shaft that goes through the frame. Pedal , rest of linkage and throw out arm are MIA, probably sold with the clutch assy and tranny.
Old 01-24-2009, 03:07 PM   #12
dwcsr
Hollister Road Co.
dwcsr's Avatar
Same place you got the clutch pedal. you can get a fork there to
info(at)thoroco.com
Old 01-28-2009, 04:02 PM   #13
Knothead
Knothead's Avatar
I did find a clutch fork that looks like the correct part, GM # 839240. Description says for earlier model car?
Old 01-29-2009, 12:55 PM   #14
renegade6
I may have an extra brake pedal I could make you a really good deal on. If I don't have one now, I will shortly when I convert to a firewall M/C.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 01-29-2009, 01:09 PM   #15
OrrieG
OrrieG's Avatar
I did a search online and at stovebolt and found the same thing. Difference is probably the bellhousing. There was some discussion about pivot points being different but I could not find a specific place that told which would interchange. You might go to www.stovebolt.com and ask the question over there.
