01-08-2009, 05:36 PM | #26 |
Re: 6 lug rotors on 71-87 c10 spindles
I would go forward with the C10 LCA and C10 ball joints. I don’t know how readily available C20 ball joints are at a local parts store nor know how much they would run you if they should fail. I have a 62 and that was one of the driving reasons for converting my front to something newer... price and convenience ...just MHO.
01-08-2009, 06:08 PM | #27 |
3/4 ton ball joints for an 85 C20 are $20 and instock at the local autozone.....
Here's the breakdown. Spindle Conversion route of 3/4 to 1/2 ton: ECE conversion spindle $269 CPP 6 lug rotors $129 DONE. Control arm swap LMC repo lower control arm $300 CPP C10 drop spindles $219 CPP 6 lug rotors $129 DONE. I'm going with the conversion route for now. Just ordered the conversion spindle from ECE..... And I do want to say that I've spoken with CPP and ECE in the past two days and ECE does have some nice guys working over in their customer sevice dept. The guys at CPP sounded like they were pissed they had to come to work. |
01-08-2009, 06:55 PM | #28 |
You have a C20 c.member & C20 a-arms in your posession now? If so, swap to an 88-98 lt. duty 3/4 ton disc set-up.
It uses the 88-98 style of spindle which requires a larger BJ pilot hole in the lower a-arm vs. traditional dics swaps using 71-87 parts (which require C10 lower arms). IIRC the required parts breakdown goes like this..... C-20 lower a-arms (uppers are the same BJ bolt pattern & thus interchangeable) 88-98 spindles (w/brake stuff.... stock or dropped) 88-98 lower BJ 88-98 upper BJ 88-98 6-lug lt-duty 3/4 ton rotors
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-08-2009 at 06:57 PM. |
01-08-2009, 09:01 PM | #29 |
I read through the threads before about that swap. I'll stick with this for now. Thanks for the info though, just too many different parts to remember.
01-08-2009, 09:22 PM | #30 |
Guys,
I used CPP parts to convert my 65 C10. The Western brand spindles (87 type) were excellent. The 6 lug rotors I believe are Chinese but they seem to work well. I ordered plane rotors but CPP sent slotted and vented!! I'll take em. One of the tie rod conversion adjusters was wrong but they took care of it. I had to use 1/4" wafer spacers to get my 15" steel wheels to clear the calipers, but that's OK. I am very happy with the end result, excellent stopping power. Part of the never ending saga of old Chevy truck brake upgrades. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
01-08-2009, 09:54 PM | #31 |
[QUOTE=Daniel 61 Apache;3071947]Didn't your truck have 88-up spindles on it? I thought that the 73-87 spindles were different from the 88-up........
quote] I'm sorry i didnt specify as i have more than one project. I had cpp rotors on my 63 that i sold to another board member, and on my crew i went with 88-up stuff.
http://67-72chevytrucks.com/vboard/s...d.php?t=304940 |
01-08-2009, 10:10 PM | #32 |
01-08-2009, 10:46 PM | #33 | |
That's them. TR
01-08-2009, 11:44 PM | #34 |
07-19-2009, 02:06 PM | #35 |
Rollin' Old Skool
any other options for keeping the steel wheels? i'd like to convert to 6-lug discs, but i'd like to keep stock-type steelies
07-19-2009, 10:03 PM | #36 | |
60-66 Nut
10-02-2017, 08:30 PM | #37 |
I have a 64 C10 Fleetside, I installed a front end from an 81 and wanted to keep the six lug wheels. I ordered a set of the 6 lug rotors and they didn't fit. Too deep and too big of bearing on the inner. Come to find out mine is a 1" thick rotor that is 4.69" tall. The 6 lug is 1-1/4" and like 4.95" tall or something. So does anyone know of a 6 lug 1" thick rotor?
10-02-2017, 08:44 PM | #38 | |
67-72 parts collector,…
You will need to swap to 1-1/4" spindles and calipers. And inner bearings, as you know.
10-02-2017, 08:47 PM | #39 |
Well that sucks. I guess the front end will be 5- lug for a while. Thanks for info.
10-03-2017, 10:50 AM | #40 |
Poverty cap & poker face. We won't tell.....
