Old 01-09-2009, 01:10 AM   #1
windmill
windmill's Avatar
need help-pulling the bed off
Alright guys, i'm going to pull the bed off my wifes swb truck. Where do i unplug the wiring for the taillights at. any hints. What the best way to pull the bed off ? thanks for any info. Also this is a 67 bed too.
soon to do a build up too.
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
Old 01-09-2009, 01:18 AM   #2
MonteSS454
MonteSS454's Avatar
Re: need help-pulling the bed off
The plug in is on the inside of the frame on the drivers side, 8 bolts and if I remember 6 9/16" and 2 3/4" nuts (Ratchet wrenches work wonders on this part) and if the rear wiring hasn't been torn into already there will be wiring loom holders attaching the wires to the backside of the bed that will need to be cut or popped out unless you're removing the assemblies.
All that and some buddys or a cherry picker on a flat level surface and some 4 x 4's.
MonteSS454 is offline   Reply With Quote
Old 01-09-2009, 02:07 AM   #3
sameyrasmea72
sameyrasmea72's Avatar
If the wireing is all stock it will plug in right here and the will be a wire coming down from the harness to the license plate light.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-09-2009, 09:58 AM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Get an engine crane, use straps or ropes and lift up the bed. You can also use The One Man Cab And Bed Dolly. But you will have to build it.
http://www.lewisfabricationdesign.com/products.aspx
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-09-2009, 10:44 AM   #5
nac593
I used a engine hoist. It wasn't as bad as I was expecting. It's not that heavy.
nac593 is offline   Reply With Quote
Old 01-09-2009, 10:44 AM   #6
cdowns
cdowns's Avatar
most times it's easier to just grind the heads off the bolts holding the bed to the frame. that way you avoid damaging the square holes that they go into
Old 01-09-2009, 01:38 PM   #7
windmill
windmill's Avatar
THANS guy's.. this will help.
72 swb pickup
1967 chevelle ss
Old 01-09-2009, 02:34 PM   #8
tim21391
tim21391's Avatar
my friend and i and his girlfriend took bed tipped it on its side and tipped it over so it wouldnt mess up my bed sides since i thought it has more support on its top and then clled two more guys over and moved it out back behind the shop im working at...no worries on people stealing it it weighs a ton
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-09-2009, 02:43 PM   #9
meansting04
meansting04's Avatar
i used 3 guys and a case of beer. Swaped out a long bed in about an hour with the harness fished back down through the light assys. It wasn't too bad. It was well worth it for a good bed.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 01-09-2009, 02:43 PM   #10
windmill
windmill's Avatar
Well that did not take long. Just a little over a 1hr, by myself..... i need to start a builds thread,and some pics too
72 swb pickup
1967 chevelle ss
