Old 01-08-2009, 11:47 PM   #1
DrtyJack75
67 Fleetside compared to 69 Step??
Is there a difference from a 67 SWB Fleetside and a 69 SWB Stepper??
Will the 67 Body drop right on a 69 frame or does it take mods??
DrtyJack75 is offline   Reply With Quote
Old 01-09-2009, 12:00 AM   #2
OARNGESI
OARNGESI's Avatar
Re: 67 Fleetside compared to 69 Step??
The beds and front clips are differnet but the frames are the same
OARNGESI is offline   Reply With Quote
Old 01-09-2009, 12:02 AM   #3
DrtyJack75
perfect, thanks....I have a 67 and would love to do a frame off, but dont want my truck to be down that long (especially since I aint even driven it yet). BUT then I have access to a 69 so maybe Ill start with that...
thanks, I love this site.......makes alot of research really fast!
Old 01-09-2009, 12:04 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
We put a '67 front clip and cab on a '69 frame without a problem.
There are a few minor differences in the frames, but nothing that causes a problem.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 01-09-2009, 12:30 AM   #5
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Frames are NOT the same. The 67 frame has a dimple. But yes, as far as I remember the 67 will swap onto the 69.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-09-2009, 12:34 AM   #6
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Originally Posted by DrtyJack75 View Post
perfect, thanks....I have a 67 and would love to do a frame off, but dont want my truck to be down that long !
Take your time and fix up the '67!
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 01-09-2009, 01:49 AM   #7
sameyrasmea72
sameyrasmea72's Avatar
a 67 frame does not have the dimple for the PS gear box, and a 67 has smaller holes on the core support mounting brackets. So the mounting kits/rubber mounts are different on 67 (and maybe 68, not sure). So keep that in mind when ordering them. This frame is a 69.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-09-2009, 05:58 AM   #8
Yup,67/68 core support bushings are different.That sounds like a good plan.That "domple" mentiond that isn`t in`67 frames is to fit the power steering box which`67s didn`t use.They used a manual box and an early design ram-type power steering.There are remedies to enable use of new design p/s boxes.But,with your plan it`s taken care of.I am building a`67 on a`71 frame,so I got disc brakes out of the deal.
Old 01-09-2009, 09:27 AM   #9
Gray Ghost
Gray Ghost's Avatar
There's one more difference...the frame rails near the motor mounts are wider on a 67 by about an inch. If you have headers of certain types [like Hedman shorties], you might have to cut the frame a bit for them to fit without rubbing.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-09-2009, 05:31 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If building from the ground up, you are better off with a 71 or 72 frame. The steel is stronger in addition to all the stuff listed above.
