#26 |
Re: December Front Kit Special! $149.99
#27 |
i just ordered mine today! so stoked! btw, may order the arms for phase II of the rebuild but right now i wanna get her on the road. ...i miss driving it
#28 |
Do these bags have the bump stops intagrated as do re7 if so post phone to call suppyer
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
#29 |
This deal had perfect timing. I just ordered all four yesterday, can't wait to get a rolling chassis put together.
#30 |
Loading.....
I tried calling about 10AM your time this morning but no answer... are you guys open this week?
Card in hand ready to spend! ![]()
-M7 '69 SWB GMC 5.7 EFI ‘69 C/10 SWB patina survivor ‘71 GMC K20 '72 K5 1-ton gear 468BB ‘86 K30 GMC High Sierra C&C Single Cab '96 SWB Single Cab 5.7 ‘99 SWB Z71 Single Cab '00 SWB Single Cab 5.3 '01 K2500 Yukon Safari 6.0 ‘06 2500HD Single Cab C&C Duramax 4x4 '08 1500 crew '11 2500HD Single Cab Duramax 4x4 |
#31 |
#32 |
Update!
This special has been extended til the end of January. 63-87 Brackets & 2 D2600 Airbags = $149.99 plus s&h or 63-87 Brackets & 4 D2600 Airbags = $249.99 plus s&h Thanks to Airlift for allowing us to continue this offer! |
#33 |
VA72C10
![]() Join Date: Mar 2008
That's great news....lets me save up to buy everything from you at once!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#34 |
Truck Junkie
![]() Join Date: Aug 2008
Ordered mine today!
#35 |
Tried to call.. No one home!! sent you fella's a PM. Hope someone gets back to me!
Thanks |
#36 |
#37 |
calling you back now... Phone tag, game on!
#38 | |
![]() Join Date: Aug 2005
This is excellent news! I thought I was going to miss out
'73 C-30 3+3 Dually 454/TH400 '74 Fleetside 350/TH350 (SOLD) '69 Nova 350/TH350 (project FOR SALE) '63 Nova 305/TH350 3.73 posi (the wife's project) |
#39 |
Been considering baggin my burb (suville) but concerned about ride height and handeling, If I use these can-will I have equivelent to a 3.5-5 drop and will it handle hard driving asi in performance cornering and such, I gotta 507 BBC(cad) to go in after suspension is dun I've followed and read most on here but still not convinced . I am looking for the same stance the Tim Christins burb has but it needs to handle too!
#40 | |
VA72C10
#41 |
I've got ECE 2.5 dropspindles and dont need or want to raise or lower once I obtain the 3.5-5 drop, and only considering schrader valves for filling as there would be no need to alter ride height stance. Due to funds or rather lack of I will most likely run a 15" truck ralley with as tall a tire as available
#42 |
I am looking at getting the 4-bag kit to set up on my 63. For the rear I am planning on doing a direct bag over trailing arm setup in place of the old springs. Do i need to also get the rear bag adapter plates from SD.com in order to make things work and bolt up? Also, do these kits come with all the needed grade 8 hardware?
Any info, advise and especially PICS! would be great, Thanks! |
#43 |
Anyone??
#44 |
67-72 parts collector,…
![]() Join Date: Nov 2002
You can bolt the bag directly to the trailing arm with a 3/8"x4" bolt and washer. On top you can bolt the rear bag directly to the frame. You will need to drill 2 holes in the frame for a bag mount and 1 larger hole for the air bag fitting to stick up through the frame. I don't believe the bags come with bolts.
Use the "search feature" in the suspension section,... there should be plenty of pics.
#45 |
Like this one:
#46 |
lowlife,
Thanks for the info and great pic! I am looming closer to buying the kit. I am not really to that part of the build but with a price like this I dont know how to look past it. |
#47 |
I may have missed it, but do these bags have internal bumpstops like slams?
Do they baloon when inflated like firestones or no balooning like slams?? Also, because I'm not familar, any suggestions on best, economical way to bag the rear of a 65 GMC leaf spring truck? I'm on a tight budget.
Tim Road Hounds |
#48 | |
Blaze-Air
#49 |
VA72C10
Re: December-January Front Kit Special! $149.99
Hopefully someone else will chime in, but from what I read, there are no internal bumpstops, but they do not baloon. Also, they are supposed to have a little more useable stroke (max higher and lower raise and lowering) and have a slightly more comfortable ride vs. the slams which are more sporty.
#50 |
A guy with a truck
I have them on the back of my truck. They do ballon, but only slightly. Bumpstops- dunno? Ride quality is very good compared to slams and they seem well made- no problems so far...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
