12-18-2008, 01:35 PM | #26 |
Neighborhood Pickle Slinger
Re: Who has Subs under their seat?
I have a Subwoofer from a Bose Acoustimass 3 System with a 125 Watt Amp under my seat.
The Port is directed to the back and I had to raise the seat a little with spacers. I sure wish I could fit my Hifonics in there from my Renault. Probably blow out my windows though.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
12-18-2008, 02:19 PM | #27 | |
The tank in these trucks is 21 gallons.Not 1/2 as much but 3 more gallons than a Blazer tank. You gain alot of behind the seat area,but not enough for the spare tire that was removed from where the tank was installed. So,it`s a trade-off and a matter of personal opinion,preference,and priority.
01-09-2009, 05:38 PM | #28 |
Here is my setup. It is a 6" Bazooka tube and I just put it in the center and I have the factory bench seat and it is about 2 inches from the bottom side of the seat. I also put my deck under the passenger side of the seat and used a aftermarket boat housing and put the amp on the drivers side. I put the antenna in the passenger side "B" pillar and it does good there. I put 2 4x6 speakers under the factory speaker hole in the dash. I have the factory block off plate on the dash so there are no signs of the radio. It really sounds good and has a really good sound to it. I have had friends think I have some 10's behind the seat. So I can listen to plenty of tunes, keep a stock look and leave the windows down and not worry about someone tearing up my dash. Also, the radio has a remote and I put a stick on outside mirror on the heater box below the dash and it makes the remote work great.
01-09-2009, 06:06 PM | #29 |
Eat My Rust
That's slick. Where'd you get the floor mount for the headunit?
01-09-2009, 06:15 PM | #30 | |
Boaters world. It is made by sea worthy and it is just an under dash radio mounting kit. Last edited by grancuda; 01-09-2009 at 06:21 PM. |
01-09-2009, 07:09 PM | #31 |
Sheesh, tough crowd! C'mon Bama, guys, that first post (Ahem..."Heaters" , "Real Flame Jobs", ect.) was mostly my sarcastic side making a poor attempt at humor, that being said, heres another:
You are trying to upgrade/add components to your rig but are runnin out of space, right? Money is an issue so moving the tank or buying smaller components is out. The way I see it, that leaves you with a couple options , if you were bound and determined to fit those 12's under the seat you could (* Now I have to borrow one of our UK friend's terms), "French" a couple of mounting brackets or add a few spacers (NOTE: Phone books may be too unstable and lead to accident or personal injury) designed to elevate or RAISE the seat a couple inches, hence giving you additional clearance for your 12's (Or Bazookas!), then you bolt em in, and reinstall seat leaving you plenty of space for additional amps/cables/cd changer (Best of all you keep that undersized container of extremely flammable liquid snuggled up behind you in the cab!). Speaking of phone books, I had a theory and wanted to test it out so I placed one on my stock seat in my 72, slapped on my 10x cowboy hat , and hopped inside the cab. I was able to sit comfortably and not bump my head so I am absolutely positive this just might work. But if not, then there is always option #2: Remove seat, trace the subs outline on floor in chalk (I know you have seen CSI), take your sawzall and cut out said outline, "French" (* See above note) up a couple of brackets, mount your subs (Comes with option of using duct tape and scraps of blue tarp for in climate weather), reinstall seat & other components, and WALLAH! sweet sounds of music! All that being said I agree with special-K: "...it`s a trade-off and a matter of personal opinion,preference,and priority." Except my cab tank hold 16 Gallons... AK ______________________________ 1972 K10 Custom Deluxe 350/350 2008 Suburban LTZ White Diamond 1972 F100 302 "Why Build It If You Can't Drive It?" |
01-09-2009, 07:37 PM | #32 |
AK72K10, your sarcasm and witty humor cracks me up! I'm typing this on my laptop driving down the road...damn....I dropped my cig lighter, hold on, I'll find it..................
01-09-2009, 10:03 PM | #33 |
accepting donations
Buy a solo baric
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
01-09-2009, 10:30 PM | #34 |
Dont know if it helps but i built a console that fit between the seat and the dash that housed a 12 inside.
01-10-2009, 09:17 AM | #35 | |
English Chevy Owner
Are you deliberately trying to be offensive or does it just come naturally?
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
01-10-2009, 10:53 AM | #36 |
