Old 01-13-2009, 01:27 PM   #1
mkmc69
mkmc69's Avatar
Rearend swap?
I have a 67' short bed step side that I am just getting started on. I would like to convert to 5 lug from the current 6 lug setup. I have already aquired a complete 86' frame with suspension. I have the chance to purchase a rearend from a 71' GMC which has the leaf spring suspension. So I guess my question is what would my best option be keeping in mind that I would like to retain the coil spring setup. Should I use the rearend from the 86' and attatch my coil spring perches to, would the 71' rearend be better? Also would like to know if I could just swap the axles from either the 86' or 71' to the 67' housing? Thanks for any info!
mkmc69 is offline   Reply With Quote
Old 01-13-2009, 02:01 PM   #2
lowriden58
lowriden58's Avatar
Re: Rearend swap?
best bet would be to sell both and buy a coil spring rear. the leaf rears dont have the track bar mount so you would have to buy or fab a mounting stud/bracket. 86 i believe is too wide, 71 is alittle wider than your 67 but would work. neither of the axles will swap into your rear.
BTW welcome from maryland
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-13-2009, 02:40 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Rearend swap?
im putting an axle out of a 76 in my 67, i got ccp's axle swap kit, got perches and a track bar with mounts. looks pretty easy.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-14-2009, 11:28 AM   #4
mkmc69
mkmc69's Avatar
Re: Rearend swap?
Ok, thanks again for the info i'm still learning.
Old 01-14-2009, 05:47 PM   #5
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: Rearend swap?
Use the '86 rear end housing: It's getting harder and harder to find good 67-72 12 bolts that aren't rusting badly inside from sitting 2" deep in mud in a junkyard. Note that the 67-70 rear ends are narrower than the 71-72 (because GM increased the front track width with disc brakes, they needed to increase the back somewhat).
I just swapped my C20 Eaton rear end with a 74 12 bolt. True, you do have to remove the leaf perches and weld on the trailing arm pads, and then get an adjustable/custom panhard kit (worth it anyway unless you stay at stock height). Biggest issue with using a leaf rearend is setting pinion angle correctly when you weld on the coil pads. There isn't much room for error (ask me how I know!).
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 01-14-2009, 06:43 PM   #6
GMC3
Re: Rearend swap?
I converted my 70 to 5 lug when i switched to disc up front and just pullled my axles and had them re drilled to 5 lug and hub shaved down at a machine shop. very easy pretty inexpensive too.
GMC3 is offline   Reply With Quote
Old 01-14-2009, 07:59 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Rearend swap?
okay, im highly entertaining the idea of what gmc3 said, swithcin my 6 lug to 5 lug by doing what he said, can someone explain that a lil more thanks!
John
1999 Toyota Tacoma 4x4
Old 01-14-2009, 09:01 PM   #8
yellowGT
yellowGT's Avatar
Re: Rearend swap?
When they re-drilled your axles did they just drill the holes or made them with the little ridges or slots whatever you call those things? I know they sell some studs that dont require the slotted thingies. I was thinking about doing the same thing but wasnt sure about the holes
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 01-14-2009, 09:08 PM   #9
oldblue1968chevy
Re: Rearend swap?
is it a dangerous thing, or is it just perfectly safe?....
liek to swap to disk brakes....5 lug's cheaper...
John
Old 01-14-2009, 11:28 PM   #10
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Rearend swap?
If done correctly by a reputable machine shop it is safe.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
