Old 01-14-2009, 06:49 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
oil pressure sending unit
where is the stock one located at i just bought my last gauge to complete my gauge cluster today also bought some pumice soap witch i don't know how i lived with out it lol. But here is a pic of the 3 gauges i have done not including the new one
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 01-14-2009, 07:02 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: oil presure sending unit
the back of your block right behind your intake bro
it looks like a boobie on a brass fittign with a single wire hanging off of it..
also some of the later models had a two pronged one on the drivers side of the block
my 83 has the wiring and the guage but only uses the one on top..
i just did that project three weeks ago
p.s. DONT over torque the brass fitting it will shred apart int eh hole.. not to hard to get out.. but not everybody keeps aset of pipe extractors around..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-14-2009, 11:11 PM   #3
pokethesmot
whats the size of the whole
Old 01-14-2009, 11:17 PM   #4
78 Chevyrado
It's in the circle... don't know what sise it is.
78 Chevyrado is offline   Reply With Quote
Old 01-15-2009, 02:50 AM   #5
dammitmitchell
the pollock
id use a 45 degree angle isntead though. i had serious issues clearing my highrise intake with the 90 degree.. coundlt tighten it all the way down so it leaked alot
Army vet 02-08
Old 01-15-2009, 12:19 PM   #6
pokethesmot
could i use the stock oil pressure sending unit or do i have to use the one the gauge cam with
Old 01-15-2009, 02:40 PM   #7
James McClure
One shot, one kill.
Poke. The "sender" behind the distributor is for the electric choke and or the oil pressure "idiot light". From the factory a truck that came with guages, the sender is mounted just above the oil filter. The thread size is 3/8 pipe. Normally it is attached thru a 90 degree firtting. If yours came with lights this passage is plugged. You may need a 1/4" square drive to pull it out. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 01-15-2009, 02:49 PM   #8
pokethesmot
so unhooking that one would be a bad idea since i have an electric choke and mine came with an idiot light but the thing is the engine has been swapped out and the oil filter is attached to my fire wall so where am i suppose to stick this thing to
Old 01-15-2009, 03:24 PM   #9
James McClure
One shot, one kill.
Poke. I've never seen a firewall mounted oil filter. Fuel filters on diesels yes. Oh well. There will still be a plug above the adapter where the oil filter lines hook to the motor. jim
Old 01-15-2009, 03:28 PM   #10
78 Chevyrado
Sorry about that, It IS that can lookin thing behind the left exhaust manifold. That engine had two of everything to run the TBI.
Old 01-15-2009, 03:28 PM   #11
pokethesmot
the guy put in a remote filter and an oil cooler
Old 01-15-2009, 08:59 PM   #12
asphaltburner
asphaltburner's Avatar
Yo! poke!
There's a couple of places on the block to access the oil chambers for a sender. Space is seriously limited behind the distributor, but the small, "idiot light" type sender fits there nicely. The larger "can" that an oil pressure guage requires will fit above the old oil filter location, and I've used the third location, behind the alternator for the oil pressure gauge sender for my Camaro and my FRANKENTRUCK, but it takes a bit of plumbing to fit it in that location due to the tight space,...still, it's bigger than the spot behind the distributor and more accessable.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 01-15-2009, 09:45 PM   #13
dammitmitchell
the pollock
dude i used the "stock" boobie shaped sendign unit my truck HAD both and HAD both plugs but it has a 350 swap in it..
i was told recently that you want to take the oil pressure from AS far AWAY from the pump itself.. IE: the red circle on the red block..
soo i would use the aftermarket sender in the TOP hole..
that's what i was told and my stuff works fine..
i jsut plugged the side hole above the filter because it kept loosenign and leaking..
Army vet 02-08
