Old 01-16-2009, 09:13 AM   #1
Prostreet 72
Prostreet 72
Prostreet 72's Avatar
What is the significance of these numbers?
I originally thought these were some sort of salvage numbers, but I see them on the cowl of alot of peoples trucks on this site. Are they manufacture markings?
Chris
Prostreet 72 is offline   Reply With Quote
Old 01-16-2009, 09:31 AM   #2
Re: What is the significance of these numbers?
Yup!
Old 01-16-2009, 09:41 AM   #3
Grapdawg
Driven a 72
Grapdawg's Avatar
Yep had those numbers to. I thought the same thing, salvage numbers. Now i know. Kinda weired
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 01-16-2009, 10:01 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Check out kyull build thread...http://67-72chevytrucks.com/vboard/s...&page=18....he had them repainted back on his firewall....pretty Kyull!!!LOL
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-16-2009, 12:59 PM   #5
10pointgmc
10pointgmc's Avatar
they are factory numbers and most people would try to leave them its a step toward original
10pointgmc is offline   Reply With Quote
Old 01-16-2009, 01:18 PM   #6
Prostreet 72
Prostreet 72
Have you seen this thing? I think those marking will be the only original things left by the time I'm am thru with this build. Check out the "Green Monster" build. I may put them back on it if it stays green and white.
Chris
Old 01-16-2009, 01:20 PM   #7
Prostreet 72
Prostreet 72
That may be a cool thing to do. Then regardless of the color I go with, it works.
Chris
Old 01-16-2009, 01:27 PM   #8
10pointgmc
10pointgmc's Avatar
it just depands as you said if your going for original or not for a restore save them for a custom or driver paint over them for the look you want under the hood
Old 01-16-2009, 01:37 PM   #9
thirdstreettito
Resident of Here
thirdstreettito's Avatar
I'm going to repaint mine by pinstriping them like kyull did.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-16-2009, 02:26 PM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
Chris, they should be your VIN...if I remember correctly
Geoff with a G
Old 01-16-2009, 03:24 PM   #11
CST*TEN in Katy
I asked the same thing a while ago.
http://67-72chevytrucks.com/vboard/showthread.php?t=264011&referrerid=18111[/URL]
I never did figure out the T4
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest.
1989 Suburban
1971 Sleekcraft 455Olds Berkeley
1992 SC400 pimp ricer
CST*TEN in Katy is offline   Reply With Quote
Old 01-16-2009, 05:19 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is the model number... not VIN.
We are looking at the firewall of a 1969, 2 wheel drive, 1/2 ton, LWB, fleetside truck with a V8
T4 could mean a million things from an assembly line worker's ID number, time code, even just a note meaning custom ordere truck.... anything you can think of, it COULD be.
Old 01-16-2009, 06:17 PM   #13
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks for the correction LHM.....
Geoff with a G
Old 01-16-2009, 08:55 PM   #14
Prostreet 72
Prostreet 72
Strange. It is titled as a 1972. All of the numbers match up, and the plates match the title. Are you sure it is a 1969 truck?
Chris
Old 01-17-2009, 01:25 AM   #15
Longhorn Man
brain fart.
Thats what I get for trying to do it from memory
That model number is actually missing the year... it would nave been between the 9 and the 3.
sorry bout that.
Old 01-17-2009, 01:31 AM   #16
FlartBastinSr
What was used to make these markings? Some sort of paint?
FlartBastinSr is offline   Reply With Quote
Old 01-17-2009, 01:32 AM   #17
Prostreet 72
Prostreet 72
brain fart.
sorry bout that.
Scared me for a moment. I thought I had a stoled truck. On the other hand, it would explain the bullet holes in the floor board.
Chris
AKA; Prostreet 72
Green Monster Build Tread
Old 01-17-2009, 01:48 AM   #18
Longhorn Man
Chalk in wet paint from what I understand.
I've cleaned them off a firewall with degreasers and elbow grease
Old 01-17-2009, 03:25 AM   #19
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I thought it was grease pencil.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-17-2009, 03:38 AM   #20
Willys47
Willys47's Avatar
I found the number 503 on the fire wall behind the motor after it was pulled It looks like it was in black felt marker and then painted over.I had know idea why it was there untill I looked at the paint code on the spid light green 503 I belive it was to let the painter know what cab was to be sprayed light green.The truck was built in Oshawa Ont Canada
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
