Old 01-17-2009, 03:12 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Haulin with bags?
Anybody here have pics of a bagged truck hauling stuff in the bed? Like plywood or anything?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-17-2009, 08:13 AM   #2
Re: Haulin with bags?
No pictures,but buy ones with proper ratings and you`re good to go.Air bags are used on semis and buses.I installed bags on four corners of my`95 K3500 work truck.I removed most of the rear leafs to make them soft enough for the bags to dominate.I got them through A&W Direct Tow Truck catalog.AirLift has been selling bag for many years as a payload increaser either within coils or mounted indepandently.
Old 01-17-2009, 08:30 AM   #3
thirdstreettito
Resident of Here
Thanks. I know about the load leveling ones. I want to see bagged(slammed) trucks hauling.
~Bradley~
Miss having a truck
Old 01-17-2009, 08:38 AM   #4
Senator350
Senator350's Avatar
I think most people who slam their trucks typically STOP using them as trucks. (one of my biggest pet peves) I'm not sure of the exact dimensions... but, if you tub a bed to stop tire rub, then you probably can't even FIT a sheet of plywood in between your wells. IIRC a regular fleet bed is likt 4' 2" between wheel wells
Which is fine... for a "lifestyle truck"
RN U OVR
Senator350 is offline   Reply With Quote
Old 01-17-2009, 08:41 AM   #5
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Do you have a website you could give us? I would like to check this out myself and see if they have something to fit my '67.
Thanks.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 01-17-2009, 08:48 AM   #6
Senator350
Senator350's Avatar
Thanks.
Just a guess, but Special-K probably had to figure out his own:
1. ride control system
2. air bag brackets
3. desired minimum and maximum height of bag
4. desired load capacity
5. plumbing
You can pretty much go to your local spring shop, and they can assist you with bag choice. And, any of the air suspension boys can sell you ride control... but you're still going to have to figure some things out on your own. UNLESS you want to scrape your frame on the pavement THAT comes in a kit!
RN U OVR
Old 01-17-2009, 08:59 AM   #7
Hard On Parts
Hard On Parts's Avatar
That is what trailers are for:
Hard On Parts is offline   Reply With Quote
Old 01-17-2009, 09:06 AM   #8
Senator350
Senator350's Avatar
B E A UTIFUL satin GMC! 22.5s or 24.5s?
Hard On... You are obv. not the "most people" I refered to in my first post. But, I bet you can't even fit 1/2 a sheet of standard ply in any of those beds
RN U OVR
Old 01-17-2009, 09:13 AM   #9
Hard On Parts
These are two buddies trucks, I have another friend that is bodydropped 4" but he hauls concrete, 2X4's and plywood all the time. His truck bed looks like any other contractor bed, beat up.
Old 01-17-2009, 09:22 AM   #10
Hard On Parts
This used to be my truck, I built it and sold it to a friend.
Leaf rear with airbags on schrader valve to haul his 24' boat. When he was roofing his garage we took it down to pick up plywood and shingles. Guy running the forklift was scarred to put the plywood in the bed. He kept asking "Are you sure?" over and over. 13 sheets went in and the truck did not squat more than 2". We drove out and went back to his house no problem.
The only problems this truck has is getting high centered on speedbumps......
Old 01-17-2009, 09:51 AM   #11
Senator350
Senator350's Avatar
schrader valves... hmmm. I think I had one of those in my old caprice classic with a 267.
RN U OVR
Old 01-17-2009, 09:56 AM   #12
My`67 project with 4/6 static drop and no c-notch will eventually get bags to replace the coils so that "I can" haul and tow.
I wasn`t just refering to auxilary bags.The ones on my 1t used with 2 leafs "was" the raer suspension with the leafs acting as mounts/locators for the axle.On front they were auxilary to keep the tweeked t-bars from saging with a load on my ladder racks.It was lifted w/o a lift kit and I coul drop the rear for a better working height while on the job.
Old 01-17-2009, 11:01 AM   #13
wdrthird
wdrthird's Avatar
This is the only pic I have of the truck loaded. Its not a big load, just some camping gear, but I do still use it as a truck. When we go camping for a week I load it down pretty good with firewood, stocked ice chests and all my other camping gear, but I also use it to haul plywood, help friends move, whatever I need to haul. The truck was built to be a daily driver and still useable as a truck, so the gas tank was relocated under the bed and the air tank is behind the seat to keep the bed open. Its got 22x9.5's in the rear with stock width wheel tubs, but the bed floor was raised 5 inchs so the fuel cell could be raised so it wouldnt drag. One thing to remember is, to get a truck that low you gotta have a big notch up through the bed, so the floor wont be flat anymore. Hope this helps.
Dusty
wdrthird is offline   Reply With Quote
Old 01-17-2009, 12:49 PM   #14
Shane
Shane's Avatar
you had four schrader valves in that old caprice ... along with your current truck
Shane is offline   Reply With Quote
Old 01-17-2009, 03:46 PM   #15
SCOTI
SCOTI's Avatar
5/7 drop (3" spindles + 1-coil cut; flip kit on HD 8-leaf pack, 2" shackles, driveway built AOL set-up w/dbl convoluted Stones filled w/schraders mounted to the bedfloor). Still has full load capacity......
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2009, 03:51 PM   #16
SCOTI
SCOTI's Avatar
6/8 drop (3" spindles + 1-coil cut; dbl convoluted Stones in place of rear coils, 1.5" lowering blocks, relocated shocks, manual paddle contol stored under the factory bench seat, small Thomas 315 compressor & 2-gal tank). Full load capacity.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-17-2009, 04:33 PM   #17
Senator350
Senator350's Avatar
yeah yeah
But the caprice had a factory towing package with a valve in the trunk to air up. I'm not dead sure what they expected anyone to tow with that tired old 267, but lord knows it could barely pull me and a friend up a hill by the time I was driving it!
RN U OVR
Old 01-17-2009, 05:41 PM   #18
thirdstreettito
Resident of Here
Hot trucks guys! Keep em coming!
~Bradley~
Miss having a truck
Old 01-17-2009, 06:03 PM   #19
Mayo
Cool Truck
Mayo's Avatar
I'd love to get a 97-03 or so S10 and bag one. I have been wanting to do that for years. If I do ever build it, my bed wouldn't be useable though. It would have the air tank, a fuel cell, the middle cut out, and then smoke stacks in the front because I would want to put a 4BT Cummins in it. I also think it would be awesome to make it into a dually. The hardest part would be fabbing up the fenders though. I was thinking a set of current Ford dually fenders may work because those truck have a similar body line with the S10. I also think 67-72s look sweet when bagged and so do the 63-66s. I just want to be able to drive around on the ground shooting sparks all the time.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 01-17-2009, 07:35 PM   #20
OARNGESI
OARNGESI's Avatar
THEY MAKE S10 DULLYS and ship them to other countries you may be able to buy a set of fenders from one and ship them over i remember seeing a couple tacoma dullies locally
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 01-17-2009, 11:23 PM   #21
Mayo
Cool Truck
Mayo's Avatar
Thats cool, I never knew that. I will have to look into that.
Old 01-18-2009, 01:26 AM   #22
sleepertruck72
sleepertruck72's Avatar
[/QUOTE]
This is insane ! It reminds me of driving a friends 97 Chevy 1500 on the 405 frwy. in L.A. at night. We lit up the night with sparks and thought it was cool. Well we lost OD when we got to Bakersfield and we made it to Selma and the tranny was fried. Little did we know we scraped the tranny pan and were slowly losing fluid. He doesnt drive his truck slammed anymore. I hope these guys dont tear up their trucks. I must admit, those are sweet looking trucks with semi wheels !!! Someone needs to do a 67-72 that way
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-18-2009, 03:10 AM   #23
thirdstreettito
Resident of Here
One day. One day...
~Bradley~
Miss having a truck
Old 01-18-2009, 11:10 AM   #24
Mayo
Cool Truck
Mayo's Avatar
If I ever get a truck on bags, I would see about welding some metal plates to the frame so you will wear those away and not your frame or tranny or anything like that.
Old 01-18-2009, 12:12 PM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
It's just a matter of building it with your intended use in mind...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
