Old 01-17-2009, 10:49 AM   #1
69 COPO
Question on Brake Master Cylinder
I have a 1971 Chevy Super Cheyenne 4x4 I'm restoring. I have a couple of master cyl. One is a larger body with 2 reservoir the same. And the other has a larger up front and a smaller reservoir in back. Does anyone know which is correct.
69 COPO is offline   Reply With Quote
Old 01-17-2009, 05:39 PM   #2
Wrenchbender Ret
Re: Question on Brake Master Cylinder
The one with the large & small resorvoir is for the disc brakes that you have.
Wrenchbender Ret is offline   Reply With Quote
Old 01-17-2009, 06:06 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
X2 I think the other one you have is for a drum/drum application.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-17-2009, 06:11 PM   #4
cparman
sharp as a marble
Not 100% sure, but I think that is the difference between a Moraine and a Bendix power booster. I know that you could get either on my 72 Blazer, and the master cylinders are different for each. ( I too have one of each ). If you go to NAPA's web site and look up a master cylinder for you truck, I think it will ask the question which booster do you have. They have pictures on their site to help you identify which booster you have.
cparman is offline   Reply With Quote
Old 01-17-2009, 06:28 PM   #5
72 Super
72 Super's Avatar
If you have a Delco booster, your master cylinder should be the oval shaped one with both the same sized resevoirs.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 01-18-2009, 04:52 PM   #6
69 COPO
So you guys are saying either could be OK. Thanks
Old 01-18-2009, 05:30 PM   #7
john
member #16
john's Avatar
Here is my delco mc.
john is offline   Reply With Quote
Old 01-18-2009, 05:55 PM   #8
Andy4639
Old member
Andy4639's Avatar
1971 Chevy with factory disc brakes. I just replaced this booster and the master cyclinder is one I replaced a few years ago. It is a direct replacement for the orignal one.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-18-2009, 06:41 PM   #9
71 super
71 super's Avatar
Easy way to tell which type brakes you have is if the booster is black it is bendix, if gold/cadmium plated it is a delco- delco also has delco-moraine stamped into the case. Either m/c will work on either booster. My 71 has delco booster with bendix master, and 72 has delco /delco combo. If you have you original take it in- you will need it for a core anyway- and get the same configuration to go back with.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
