Old 01-18-2009, 07:55 PM   #1
Blazer Eagle
how to tell a 350 from a 400
so i found a truck that came from the factory with a 400, but i believe it may have a 350 in it, how do i tell if it is a 350 or 400? it has an edelbrock 1409 carb on it if that helps
Blazer Eagle is offline   Reply With Quote
Old 01-18-2009, 09:01 PM   #2
4everGMtrucks
4everGMtrucks's Avatar
Re: how to tell a 350 from a 400
i'm pretty sure a 400 has three freeze plugs on each side rather than the standard two that the other small blocks have.
4everGMtrucks is offline   Reply With Quote
Old 01-18-2009, 09:02 PM   #3
Red_69
Red_69's Avatar
I don't think that's ALWAYS true. Maybe someone else can chime in.
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 01-18-2009, 09:17 PM   #4
79Silv4x4
Workaholic
79Silv4x4's Avatar
What leads you to believe it has a 350 in it???
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 01-18-2009, 09:28 PM   #5
Blazer Eagle
the valve covers? say performance 350 on them, but i thought they were interchangeable
Old 01-18-2009, 09:34 PM   #6
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Harmonic Ballancer.....350 or any other small block for that matter OTHER than a 400 is internally balanced, a 400 is externally.. a 400 ballancer is not totally round someone correct me if i am wrong?..........But am pretty sure this is the way to I.D one from the other
bad6772 is offline   Reply With Quote
Old 01-18-2009, 10:02 PM   #7
chevybuldr
chevybuldr's Avatar
Not all 400s had 3 plugs on each side. Best way is casting number off the back or the front pad on the front passanger side. Look at the ballancer. All but the 400 has a smooth outer ring, no indents. 400 has an area cut out of it for the external balance.
chevybuldr is offline   Reply With Quote
Old 01-18-2009, 10:19 PM   #8
Blazer Eagle
i dont really know engines so if anyone has pictures that would help a lot so i could go look
Old 01-18-2009, 10:35 PM   #9
chevybuldr
chevybuldr's Avatar
look on the front pass side on the block in front of the head.There is a pad there with numbers stamped into the block. Unless somebody machined the motor before. Give those numbers and that will help
Old 01-19-2009, 02:40 AM   #10
Dooley
Dooley's Avatar
This thread should answer your 400 smallblock ID questions.
http://67-72chevytrucks.com/vboard/s...80#post2789780
Dooley is offline   Reply With Quote
Old 01-19-2009, 09:24 AM   #11
4everGMtrucks
according to a book written by david Vizard, in the reference section under casting numbers. the 400 small block with four bolt mains, has a casting number of 3951511, had three freeze plugs and was manufactured from 70-73. the 400's with casting #'s 3951509 or 3030817 had two bolt mains, two freeze plugs and were manufactured between 74-76. you will find the casting number on the block behind the drivers side head.
Old 01-19-2009, 11:17 AM   #12
chevybuldr
chevybuldr's Avatar
Some 2 bolts have 3 plugs on the side. The one in my 'burb does and its a 4 bolt. Plus I just finished putting 4 bolt caps on a 2 bolt block that also has 3 plugs.
Old 01-19-2009, 03:15 PM   #13
Blazer Eagle
well i know what to look for but not where
where would i look for the harmonic balancer
where would look for the casting number
and this is in a fully put together complete truck, so if these are hidden behind something bolted on i wont be able to get t o them
Old 01-19-2009, 04:31 PM   #14
Dooley
Dooley's Avatar
The harmonic balancer is located on the front of the crankshaft between the block and your lower accessory pulleys. Complete casting numbers are usually found on the rear drivers side of the block behind/below the drivers side head. Did you look at the pics in the link that was previously posted?
Here's another pic of the 400 balancer and a 1980 509 engine.
Old 01-19-2009, 07:58 PM   #15
Blazer Eagle
yeah and im 90% sure its a 350, i guess i did look in the right place there were 4 pullies and they all looked round and normal
Old 01-19-2009, 08:22 PM   #16
arkracing
Weekend Warrior
Anyway you can post a picture of your balancer? The Pulley's have nothing to do with it.
The best picture would be if you could jack the truck up and take the picture from underneath looking forward at the balancer - if there is a cutout like the one pictured above than it is a 400 (The cutout part of the balancer is facing the rear of the engine)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-19-2009, 08:56 PM   #17
BigBlocksRule
If you can crawl under the truck and look at the sides of the block, it'll tell. The 2 or 3 freeze plugs indicator doesn't work - I have a 509 casting block on the stand in my garage and it has only 2 freeze plugs, not even a boss for the third. Look at the sides of the block - if they're perfectly flat, it's a 305 or 350. If it's a 400, there will be small bulges around each cylinder, between 1/8" and 1/4" tall. Chevy only made 3 different casting numbers of 400 blocks - it'll have to end in 817, 509 or 511. The balancer is generally a good way to tell, but I use balancers with the counterweight on the inside, makes 'em look just like a 350 balancer. With this 2-freeze plug block and a balancer like I described, most casual observers will be sure it's a 350. I'm sure as hell not gonna set 'em straight.
BigBlocksRule is offline   Reply With Quote
