Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-19-2009, 03:18 PM   #1
tubbed55
tubbed55's Avatar
Front tire size
I just bought a total cost involved IFS set up for my '55 second series. I bought the standard spindles because figured dropped would be too low. I am now going to look into ordering my front wheels and tires so I can get it back rolling after I install front end. Any one have suggestions on the front wheel and tire size would look best? The rims are the Tork thruster II's. I was thinking either 15X6 or 15X7. Unsure on front tire size. The rear of truck is pro street but I don't want runners on the front. Any pics of their front tire rim combo with IFS front standard spindles? Figured I would try over here since most on the show side uses larger diameter wheels. Thanks, Ronnie
tubbed55 is offline   Reply With Quote
Old 01-19-2009, 04:02 PM   #2
djracer
djracer's Avatar
Re: Front tire size
I would put the front end under the truck and get some junk Toyota truck wheels on it till it was closer to done. I personally would lean to wards the narrower front wheel to give it more of the pro street look.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-20-2009, 10:19 AM   #3
Garagedude
Garagedude's Avatar
Re: Front tire size
I had a 15x5 rim on my truck with hoosiers on them, and to me it looked way to small for my front end. So then I went to a 15x7 with a sportsman tire and I very happy with the way that looks. But I would probably wait to you have everything done, such as disk brakes, swapping swindles, and have the front end in, cause you don't want to order the wrong offset and have it look goofy.
Garagedude is offline   Reply With Quote
